6574 Discussions
how to get layer-to-layer output in DL workbench
ShaLu
I noticed (in this post https://github.com/openvinotoolkit/openvino/issues/1551) that layer-to-layer outputs can be examined using OpenVINO DL workbench.  It is very useful for checking the workflow of the model. Could anyone know how to get the layer-to-layer outputs in the DL workbench? Thanks!
Sha
Wan_Intel
Hi ShaLu,
We are investigating this issue, and we will update you at the earliest.
Thank you.
Wan
Wan_Intel
Hi ShaLu,
Thanks for your patience.
For your information, after you have created your project in OpenVINO™ Deep Learning Workbench, you may visualize the layer with the following steps:
1.   Click “Open”
2.   Click “your model”
3.   Click “Visualize Model”
Wan
ShaLu
Hi Wan,
Thanks for your reply.
It helps to see the structure of my model. However, what I am looking for is to see the outputs of each layer when making an inference. Details can be found in the next reply I posted.
Sha
ShaLu
Hi Wan,
Following the steps you posted, I can visualize my model as the following.
However, I would like to see the outputs of each layer when making an inference, like the outputs shown in the post https://github.com/openvinotoolkit/openvino/issues/1551, which could look like this.
I have explored the DL workbench but couldn't find where to see the step-by-step outputs. I am appreciated that if you could help me with this.
Sha
Wan_Intel
Hi ShaLu,
For your information, referring to the GitHub question, the customer created a custom Python script to view the output results. The output result cannot be viewed in OpenVINO™ Deep Learning Workbench. You may refer to "Unit-test code" in this question for more information.
Wan
Wan_Intel
Hi ShaLu,
Thanks for your question.
This thread will no longer be monitored since we have provided information.
If you need any additional information from Intel, please submit a new question.
Wan
