I am trying to run a yolov3 model converted from a pytorch model from this repo: https://github.com/ultralytics/yolov3. Here is my code. The script simply exits - with no error, warning, or anything - after printing "Loading on device" and before "Reading image". This is Windows 10, openvino_2021.2.185, Python 3.6.5 (v3.6.5:f59c0932b4, Mar 28 2018, 17:00:18) [MSC v.1900 64 bit (AMD64)] on win32. Attached are the xml and bin files.
from openvino.inference_engine import IECore, IENetwork
ie = IECore()
print("Reading network")
net = ie.read_network(model="yolov3-master35.xml",weights="yolov3-master35.bin")
print("Loading on device")
exec_net = ie.load_network(network=net, device_name="CPU")
print("Reading image")
Here's a link to the .bin file
https://drive.google.com/file/d/1ZbF6EtQUvPUpjJL8xpVAfBvY4ozIx-pq/view?usp=sharing
Here is an error being thrown when loading the network in c++. I am running the code _openVino->ExecutableNetwork = _openVino->Core->LoadNetwork(_openVino->Network, "CPU"); and the error is "Exception thrown at 0x00007FFCEAFF7D3B (inference_engine_legacyd.dll) in Ocuvera.CV.Tools.NeuralInferenceTester.exe: 0xC0000005: Access violation reading location 0x0000000000000030."
Greetings,
I believe this problem is the same as the one you ha posted here:
You could go to the thread for the answer.
Thanks!
Sincerely,
Iffa
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
![](/skins/images/54BF544B471F3F61DFD338F1D58F9426/responsive_peak/images/icon_anonymous_message.png)
