6574 Discussions
mnist network result is different from Movidius's
Now I am working the mnist network realized with Movidius stick, but I have gotten the different result from pycaffe's.
python code is the following for setting;
network_blob='../networks/mnist/graph' #compile succeeded
dim=(28,28)
with open(network_blob, mode='rb') as f:
blob = f.read()
graph = device.AllocateGraph(blob)
graph.SetGraphOption(mvnc.GraphOption.ITERATIONS, 1)
iterations = graph.GetGraphOption(mvnc.GraphOption.ITERATIONS)
img = cv2.imread('../images/two-0.jpg')
img = cv2.resize(img,dim)
inp = (255 - img.astype(numpy.float16)) / 255
graph.LoadTensor(inp, 'user object')
output, userobj = graph.GetResult()
print(output)
Here is the prototxt for the network;
input: "data"
input_shape {
dim: 1
dim: 1
dim: 28
dim: 28
layer {
type: "Convolution"
bottom: "data"
top: "conv1"
param {
lr_mult: 1
param {
lr_mult: 2
convolution_param {
num_output: 20
kernel_size: 5
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "Pooling"
bottom: "conv1"
top: "pool1"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "Convolution"
bottom: "pool1"
top: "conv2"
param {
lr_mult: 1
param {
lr_mult: 2
convolution_param {
num_output: 50
kernel_size: 5
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "Pooling"
bottom: "conv2"
top: "pool2"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "InnerProduct"
bottom: "pool2"
top: "ip1"
param {
lr_mult: 1
param {
lr_mult: 2
inner_product_param {
num_output: 500
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "ip1"
top: "ip1"
layer {
bottom: "ip1"
top: "ip2"
param {
lr_mult: 1
param {
lr_mult: 2
num_output: 10
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "Softmax"
bottom: "ip2"
top: "prob"
"inp" values from movidius code are almost the same as pycaffe's which is read by "a" in following code;
#!/usr/bin/env python
import numpy as np
import pandas as pd
import os
import argparse
import time
import caffe
net = caffe.Classifier('lenet.prototxt','lenet_iter_10000.caffemodel', image_dims = (28, 28))
caffe._caffe.set_mode_cpu()
net.transformer.set_raw_scale('data', 1)
a=1 - caffe.io.load_image('three-0.jpg', color = False, ) #maximum 1
print(a)
scores = net.predict([a], oversample=False)
print (scores)
If somebody can give the good advises to me, I can send the trained parameter.
Could somebody teach the reason why I got the almost different result from pycaffe?
@KKK Regarding your results from LeNet, I was just wondering what your results were and what your expected results are. If you can provide the caffemodel file, that would be great also. Thanks.
@KKK Additionally, the Movidius SDK toolkit has an example called top5_over_a_dataset.py which uses mnist and LeNet. It may be helpful to check it out.
