6575 Discussions
multi-batch latency comparative experiment
shirleyliu
I want to test the relationship between batch size and parallel computing on GPU. I did the following experiment
device: GPU(Intel UHD Graphics 630)
model input shape: (1,3,8,8)
input image shape:(8,8)
my command is like this:
python ./benchmark_app.py -m xxx_8x8_fp16_b1.xml -i 0801_8x8.png -d GPU -api sync -niter 1000 -b batchsize
we need to focus on latency so I set the -api synchronize mode
and only thing I need to do is to change the batch size, the test result is in the following chart
batchsize
8
16
32
64
128
256
512
1024
1200
1280
1300
1500
1536
2000
2048
3000
3500
3700
3850
3900
4000
4096
Inputshape
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
GPU usage
50%
53.5%
59%
68%
75%
83%
89%
95%
94%
97%
94%
95%
98%
97%
98%
97.5
98%
99%
99%
98%
100%
100%
latency
0.35
0.39
0.51
0.66
0.86
1.38
2.57
6.54
5.7
9.94
5.96
6.80
13.19
9.56
19.19
14.23
17.41
17.76
18.68
18.61
41.57
42.41
and look at the bold numbers. It's strange that the result doesn't show the regularity of the latency increases with the increase of batch size. and specifically, if the batch size is in a particular size, the GPU usage is slightly reduced and the latency  reduced a lot
Peh_Intel
Hi Shirley,
We noticed that this is a duplicated issue from the following thread. If you need any additional information from Intel, please submit a new question since this thread is no longer being monitored.
Sincerely,
Peh
Peh_Intel
Hi Shirley,
Sincerely,
Peh
