6582 Discussions
squeezenet1.1.caffemodel" is not existing file.
manzano__juan
when trying to run the Run the Verification Scripts to Verify Installation in the isntallation guide it prompts me this :
home/user/openvino_models/models/FP32/classification/squeezenet/1.1/caffe/squeezenet1.1.caffemodel" is not existing file.
How can I fix this please? I don't know where to go to start going steps forward
Thank you,
Juan
Shubha_R_Intel
Dear manzano, juan,
My guess is that you didn't execute setupvars.sh from the same shell that you ran the scripts from. Either that or you didn't install all the pre-requisites. Please follow these steps carefully:
http://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html
Also R2019 R1.1 is now available for you to download.
Thanks for using OpenVino !
Shubha
Abramov__Hanna
Hi ,
I tried to run the first demo from R2019 R3.334  version.
The file queezenet1.1.caffemodel really does not exists.I searched inside the verstion folders.
Maybe this file exists on the older versions.
In addition the second demo with the car, worked.
Thanks and regards,
Hanna
JesusE_Intel
Hi Hanna,
There is a newer version available, OpenVINO Toolkit 2019 R3.1 (2019.3.376). Could you give it a try and let me know if you run into the same issue?
Jesus
Abramov__Hanna
[ ERROR ] Error loading xmlfile: C:\Users\USER\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16\squeezenet1.1.xml, File was not found at line: 1 pos: 0
Error
Xml file cant be reached ,I think, becouse it doesnt looking on openvino_2019.3.379 folder in the correct place.
Thanks and regards,
Hanna
Abramov__Hanna
Finally I created  files : queezenet1.1.bin , queezenet1.1.xml through optimizer by cummand:
python "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo.py" --input_model "C:\Users\USER\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.caffemodel" --data_type FP16 --output_dir "C:\Users\USER\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16"
and run the demo.
Thanks anyway,
Hanna
