Hello all,
I am getting the following error message when installing EII packages:
Failed to update packages python3 builder.py
Failed to install eii_installer took 1 minutes 49.23 seconds
I have try reinstall python, but still have errors.
Does anyone know some clues to cope with this problem~?
Please see attached screenshot from my terminal~
-Jerry
Hi Jerry,
I just installed Edge Insights for Industrial version 2.6.2 on a fresh Ubuntu 18.04 system successfully. Are you using a fresh Ubuntu 18.04 system? Do you see the same error message when re-running the installation?
Could you please share the installation log file? The log file is located in the following directory:
/var/log/esb-cli/Edge_Insights_for_Industrial_2.6.2/eii_installer/install.log
Jesus
Hello JesusE,
This is my install.log
-Jerry
Hi Jerry,
For some reason I am unable to download or open the log file (Forbidden error). Would you mind attaching it again?
Jesus
Hello JesusE,
-Jerry
Hello JesusE,
sorry, I don't know why my file can't be download, I will try it again
-Jerry
Hello JesusE,
May I have your Hardware specification and OS version
mine could be see in attached file
-Jerry
Hi Jerry,
I am using an Intel NUC with an Intel® Core™ i5-9300H CPU running a fresh Ubuntu 18.04. LTS.
Thanks for sharing the log file! I was able to download and open it, however, it does not have as much information as I was hoping. You mentioned you re-installed python, which python version are you using?
Is it possible for you to try to install the software package on a system with a clean install of Ubuntu 18.04?
Jesus
Hello JesusE,
I use command line to see the python version:
python --version : Python 2.7.17
python3 --version : Python 3.6.9
-Jerry
Hi Jerry4_Liu,
The python versions are the same on my system. I retested today on a fresh OS install and did not run into any issues with the installation. I recommend trying the installation process on a system with a fresh OS (Ubuntu 18.04).
Please give it a try and let me know if you run into any issues.
Jesus
![](/skins/images/E799062D82CA2A220ED12C6FD1960495/responsive_peak/images/icon_anonymous_message.png)
