Hi all,
I'm using Intel ECI 3.0(Debian Distribution, LTS PREEMPT_RT kernel 5.10.115-rt67-intel-ese-standard-lts-rt+, Installed by using ECI deb packages),
and I would like to enable kernel crash dump to dump whatever is in RAM (memory) to disk when the execution of the Linux kernel is halted or crashed.
I checked the kernel config parameters and It seem that the LTS PREEMPT_RT kernel doesn't suport kernel crash dump:
# CONFIG_KEXEC is not set
# CONFIG_KEXEC_FILE is not set
# CONFIG_CRASH_DUMP is not set
So, I was wondering if you could give me some advice on how to active kernel crash dump on Intel ECI 3.0 ?
And in case I have to change the kernel config parameters for support kernel crash dump, please advise me how to change these parameters.
Best regards
BUI
Please refer
https://eci.intel.com/docs/3.0.1/development/eci_build_engine.html
Step 4: Start a bitbake Environment
Please try the following
./setup.sh
KAS_CONTAINER_IMAGE=jammy-kas-isar:3.0.2 ./kas-container --git-credential-store ${HOME}/.git-credentials shell targets/kas/eci-packages-bullseye.yml
#add your kernel config
vi /work/targets/layers/meta-tgr/meta-eci-isar/recipes-kernel/linux/files/amd64_5.10_intel_defconfig
bitbake linux-intel-rt -c cleansstate && bitbake linux-intel-rt
exit
#obtain the deb package and install
build/eci-packages-bullseye/tmp/work/eci-bullseye-amd64/linux-intel-xenomai/5.10.140-4/linux-headers-intel-xenomai_5.10.140-bullseye-4_amd64.deb
build/eci-packages-bullseye/tmp/work/eci-bullseye-amd64/linux-intel-xenomai/5.10.140-4/linux-image-intel-xenomai_5.10.140-bullseye-4_amd64.deb
build/eci-packages-bullseye/tmp/work/eci-bullseye-amd64/linux-intel-xenomai/5.10.140-4/linux-intel-xenomai_5.10.140-bullseye-4_amd64.deb
Lay
Hi BUI,
I've been looking through the ECI documentation and I'm not seeing anything related to enabling kdump. Let me reach out to the development team for additional assistance. I will let you know what I find out.
Jesus
Please refer
./setup.sh
exit
Lay
Hello, Lay.
Thank you for your quick response!
I am building new deb packages following your advise, and I will update once I have some more questions.
Bui
Hi Lay, Jesus
I have built a new kernel deb packages with kernel crash dump suported config parameters following your advise, and It work well.
So I would like to close this topic here. Thank you very much for your kindly support.
Best regards
Bui
![](/skins/images/F0F49BD5F2C539F9177C31EE54F848B4/responsive_peak/images/icon_anonymous_message.png)
