Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
410 Discussions
Performing Turtle creek updates via Thingsboard server FAILS
Pranav_S_Intel
I am following instruction from README.md file under "universal_wellpad_controller/Universal_Wellpad_Controller_1.0/uwc/EdgeInsightsSoftware-v2.2-PV/turtlecreek" directory.
First command under "## Performing Turtle creek updates via Thingsboard server." fails with an error message.
Command:
$docker run -it -p 9090:9090 -p 1884:2883 -p 5683:5683/udp -v ~/.mytb-data:/data -v ~/.mytb-logs:/var/log/thingsboard -e MQTT_BIND_PORT=2883 --name mytb --restart always thingsboard/tb-postgres
Error Message:
docker: Error: remote trust data does not exist for docker.io/thingsboard/tb-postgres: notary.docker.io does not have trust data for docker.io/thingsboard/tb-postgres.
JesusE_Intel
Universal Wellpad Controller version 1.6.1 is available for download on Edge Software Hub. Please start a new discussion if additional assistance is needed as this thread will no longer be monitored.
JesusE_Intel
Hi Pranav_S_Intel,
Thanks for reaching out, I also saw the same issue when following the README.md file. Let me take a look and get back to you.
Jesus
Murni_J_Intel
Hi @Pranav_S_Intel
May I know if this is the latest available download from ESH? can you help to provide me the screen capture of the whole file structure that have been installed?
dasamara
I kindly request that Pranav_S please consider moving forward with UWC1.6 package from ESH when it is available in near future.  If the situation is more pressing then migration to UWC1.5 is an alternative.  If there is a strong need to remain using UWC1.0, please confirm this in a reply.
Dean
Pranav_S_Intel
Hi Dean, There was  no option to select particular version if I remember correctly. But I am okay using a version which works, do I need to do something specific to download different version?
Murni_J_Intel
Hi @Pranav_S_Intel
The new release for UWC package will be available latest by next week on ESH.  We will notify you once it is available for you to check on the issue from your side.
sorry for the inconvenience caused.
JesusE_Intel
