Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
434 Discussions
dock image for openvino failed
Yihongyu
When running following,
"docker build --build-arg base_image=amr-ubuntu2004-ros2-foxy-sdk:2021.3 --tag amr-ubuntu2004-openvino-sdk:2021.3 --no-cache --file amr_ubuntu2004_openvino_sdk_env/Dockerfile amr_ubuntu2004_openvino_sdk_env"
 I met following issues on Nov 1117, but  it worked well on Nov 1116.  How to fix it?
Thank you!
"File has unexpected size (24698 != 29310). Mirror sync in progress? [IP: 23.74.41.153 443]"
More detail.
Step 18/56 : RUN wget -qO - ${OV_PUB_KEY} | sudo apt-key add -
---> Running in d720704eb982
+ wget -qO - 'https://apt.repos.intel.com/openvino/2021/GPG-PUB-KEY-INTEL-OPENVINO-2021?elq_cid=6776584_ts1617122180201&erpm_id=9838162_ts1617122180201'
+ sudo apt-key add -
Warning: apt-key output should not be parsed (stdout is not a terminal)
OK
Removing intermediate container d720704eb982
---> fe571cad864d
Step 19/56 : RUN echo "deb https://apt.repos.intel.com/openvino/2021 all main" | sudo tee /etc/apt/sources.list.d/intel-openvino-2021.list
---> Running in 5ab75bcd3330
+ echo 'deb https://apt.repos.intel.com/openvino/2021 all main'
+ sudo tee /etc/apt/sources.list.d/intel-openvino-2021.list
Removing intermediate container 5ab75bcd3330
---> 35b3a5dee935
Step 20/56 : RUN sudo apt-get update && sudo apt-get install -y --no-install-recommends intel-openvino-dev-ubuntu20-2021.2.200 && rm -rf /var/lib/apt/lists/*
---> Running in c56b0113691d
+ sudo apt-get update
Get:1 http://packages.osrfoundation.org/gazebo/ubuntu-stable focal InRelease [4249 B]
Get:2 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Get:3 http://packages.ros.org/ros/ubuntu focal InRelease [4676 B]
Get:4 http://archive.ubuntu.com/ubuntu focal InRelease [265 kB]
Get:5 http://packages.osrfoundation.org/gazebo/ubuntu-stable focal/main amd64 Packages [67.6 kB]
Get:6 http://packages.ros.org/ros2/ubuntu focal InRelease [4670 B]
Get:7 https://apt.repos.intel.com/openvino/2021 all InRelease [5659 B]
Get:8 http://packages.ros.org/ros/ubuntu focal/main amd64 Packages [594 kB]
Get:9 https://librealsense.intel.com/Debian/apt-repo focal InRelease [2400 B]
Get:10 https://apt.repos.intel.com/openvino/2021 all/main amd64 Packages [29.3 kB]
Err:10 https://apt.repos.intel.com/openvino/2021 all/main amd64 Packages
Hashes of expected file:
- Filesize:29310 [weak]
- SHA512:58800073acd93d4248ef4c17aa2d1e50a1e214cbcba78a6384c2367bad97c283d8b39637f25c292a3062a58ab0208562f56953547f6f5dde2bbd4945c9c205fc
- SHA256:c66a9e4dc7294fed90dc01840c7f76322ffe7756b0a8411b44b4cf12fa023454
- SHA1:cf8fc0ac1575c749746c50a5da869142645a38a7 [weak]
- MD5Sum:ffb68bc7dc4d128c7e3755262549bbff [weak]
Release file created at: Fri, 12 Nov 2021 14:00:08 +0000
Get:11 http://security.ubuntu.com/ubuntu focal-security/multiverse amd64 Packages [30.1 kB]
Get:12 http://security.ubuntu.com/ubuntu focal-security/restricted amd64 Packages [682 kB]
Get:13 https://librealsense.intel.com/Debian/apt-repo focal/main amd64 Packages [25.8 kB]
Get:14 https://apt.repos.intel.com/openvino/2021 all/main all Packages [3585 B]
Get:15 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Get:16 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages [809 kB]
Get:17 http://archive.ubuntu.com/ubuntu focal-backports InRelease [101 kB]
Get:18 http://packages.ros.org/ros2/ubuntu focal/main amd64 Packages [909 kB]
Get:19 http://security.ubuntu.com/ubuntu focal-security/main amd64 Packages [1232 kB]
Get:20 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages [11.3 MB]
Get:21 http://archive.ubuntu.com/ubuntu focal/multiverse amd64 Packages [177 kB]
Get:22 http://archive.ubuntu.com/ubuntu focal/restricted amd64 Packages [33.4 kB]
Get:23 http://archive.ubuntu.com/ubuntu focal/main amd64 Packages [1275 kB]
Get:24 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 Packages [33.3 kB]
Get:25 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [1098 kB]
Get:26 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [1689 kB]
Get:27 http://archive.ubuntu.com/ubuntu focal-updates/restricted amd64 Packages [738 kB]
Get:28 http://archive.ubuntu.com/ubuntu focal-backports/main amd64 Packages [2668 B]
Get:29 http://archive.ubuntu.com/ubuntu focal-backports/universe amd64 Packages [7185 B]
Fetched 21.4 MB in 39s (551 kB/s)
Reading package lists...
E: Failed to fetch https://apt.repos.intel.com/openvino/2021/dists/all/main/binary-amd64/Packages.gz File has unexpected size (24698 != 29310). Mirror sync in progress? [IP: 23.74.41.153 443]
E: Some index files failed to download. They have been ignored, or old ones used instead.
The command '/bin/bash -xo pipefail -c sudo apt-get update && sudo apt-get install -y --no-install-recommends intel-openvino-dev-ubuntu20-2021.2.200 && rm -rf /var/lib/apt/lists/*' returned a non-zero code: 100
Nadia_J_Intel
Hi Yihongyu,
Do you still encounter this issue when building the docker image ? I tried to replicate the issue but did not encounter the same thing that you observed here.
Nadia
Yihongyu
Looks like following packages have an issue.
JesusE_Intel
Hi Yihongyu,
I am checking with the appropriate team on this, I'll let you know what I find out.
Jesus
Nadia_J_Intel
Hi Yihongyu,
Nadia
JesusE_Intel
