When running following,
"docker build --build-arg base_image=amr-ubuntu2004-ros2-foxy-sdk:2021.3 --tag amr-ubuntu2004-openvino-sdk:2021.3 --no-cache --file amr_ubuntu2004_openvino_sdk_env/Dockerfile amr_ubuntu2004_openvino_sdk_env"
I met following issues on Nov 1117, but it worked well on Nov 1116. How to fix it?
Thank you!
"File has unexpected size (24698 != 29310). Mirror sync in progress? [IP: 23.74.41.153 443]"
More detail.
Step 18/56 : RUN wget -qO - ${OV_PUB_KEY} | sudo apt-key add -
---> Running in d720704eb982
+ wget -qO - 'https://apt.repos.intel.com/openvino/2021/GPG-PUB-KEY-INTEL-OPENVINO-2021?elq_cid=6776584_ts1617122180201&erpm_id=9838162_ts1617122180201'
+ sudo apt-key add -
Warning: apt-key output should not be parsed (stdout is not a terminal)
OK
Removing intermediate container d720704eb982
---> fe571cad864d
Step 19/56 : RUN echo "deb https://apt.repos.intel.com/openvino/2021 all main" | sudo tee /etc/apt/sources.list.d/intel-openvino-2021.list
---> Running in 5ab75bcd3330
+ echo 'deb https://apt.repos.intel.com/openvino/2021 all main'
+ sudo tee /etc/apt/sources.list.d/intel-openvino-2021.list
Removing intermediate container 5ab75bcd3330
---> 35b3a5dee935
Step 20/56 : RUN sudo apt-get update && sudo apt-get install -y --no-install-recommends intel-openvino-dev-ubuntu20-2021.2.200 && rm -rf /var/lib/apt/lists/*
---> Running in c56b0113691d
+ sudo apt-get update
Get:1 http://packages.osrfoundation.org/gazebo/ubuntu-stable focal InRelease [4249 B]
Get:2 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Get:3 http://packages.ros.org/ros/ubuntu focal InRelease [4676 B]
Get:4 http://archive.ubuntu.com/ubuntu focal InRelease [265 kB]
Get:5 http://packages.osrfoundation.org/gazebo/ubuntu-stable focal/main amd64 Packages [67.6 kB]
Get:6 http://packages.ros.org/ros2/ubuntu focal InRelease [4670 B]
Get:7 https://apt.repos.intel.com/openvino/2021 all InRelease [5659 B]
Get:8 http://packages.ros.org/ros/ubuntu focal/main amd64 Packages [594 kB]
Get:9 https://librealsense.intel.com/Debian/apt-repo focal InRelease [2400 B]
Get:10 https://apt.repos.intel.com/openvino/2021 all/main amd64 Packages [29.3 kB]
Err:10 https://apt.repos.intel.com/openvino/2021 all/main amd64 Packages
Hashes of expected file:
- Filesize:29310 [weak]
- SHA512:58800073acd93d4248ef4c17aa2d1e50a1e214cbcba78a6384c2367bad97c283d8b39637f25c292a3062a58ab0208562f56953547f6f5dde2bbd4945c9c205fc
- SHA256:c66a9e4dc7294fed90dc01840c7f76322ffe7756b0a8411b44b4cf12fa023454
- SHA1:cf8fc0ac1575c749746c50a5da869142645a38a7 [weak]
- MD5Sum:ffb68bc7dc4d128c7e3755262549bbff [weak]
Release file created at: Fri, 12 Nov 2021 14:00:08 +0000
Get:11 http://security.ubuntu.com/ubuntu focal-security/multiverse amd64 Packages [30.1 kB]
Get:12 http://security.ubuntu.com/ubuntu focal-security/restricted amd64 Packages [682 kB]
Get:13 https://librealsense.intel.com/Debian/apt-repo focal/main amd64 Packages [25.8 kB]
Get:14 https://apt.repos.intel.com/openvino/2021 all/main all Packages [3585 B]
Get:15 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Get:16 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages [809 kB]
Get:17 http://archive.ubuntu.com/ubuntu focal-backports InRelease [101 kB]
Get:18 http://packages.ros.org/ros2/ubuntu focal/main amd64 Packages [909 kB]
Get:19 http://security.ubuntu.com/ubuntu focal-security/main amd64 Packages [1232 kB]
Get:20 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages [11.3 MB]
Get:21 http://archive.ubuntu.com/ubuntu focal/multiverse amd64 Packages [177 kB]
Get:22 http://archive.ubuntu.com/ubuntu focal/restricted amd64 Packages [33.4 kB]
Get:23 http://archive.ubuntu.com/ubuntu focal/main amd64 Packages [1275 kB]
Get:24 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 Packages [33.3 kB]
Get:25 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [1098 kB]
Get:26 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [1689 kB]
Get:27 http://archive.ubuntu.com/ubuntu focal-updates/restricted amd64 Packages [738 kB]
Get:28 http://archive.ubuntu.com/ubuntu focal-backports/main amd64 Packages [2668 B]
Get:29 http://archive.ubuntu.com/ubuntu focal-backports/universe amd64 Packages [7185 B]
Fetched 21.4 MB in 39s (551 kB/s)
Reading package lists...
E: Failed to fetch https://apt.repos.intel.com/openvino/2021/dists/all/main/binary-amd64/Packages.gz File has unexpected size (24698 != 29310). Mirror sync in progress? [IP: 23.74.41.153 443]
E: Some index files failed to download. They have been ignored, or old ones used instead.
The command '/bin/bash -xo pipefail -c sudo apt-get update && sudo apt-get install -y --no-install-recommends intel-openvino-dev-ubuntu20-2021.2.200 && rm -rf /var/lib/apt/lists/*' returned a non-zero code: 100
Hi Yihongyu,
Do you still encounter this issue when building the docker image ? I tried to replicate the issue but did not encounter the same thing that you observed here.
Nadia
Looks like following packages have an issue.
Hi Yihongyu,
I am checking with the appropriate team on this, I'll let you know what I find out.
Jesus
Hi Yihongyu,
Nadia
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
