- Contrassegnare come Nuovo
- Preferito
- Iscriversi
- Disattiva notifiche
- Iscriversi a feed RSS
- Evidenziare
- Stampare
- Segnalare contenuto inappropriato
Link copiato
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Gordon,
Assuming you have strong connection, it may due to VPN if you are using it or firewall that block the packet, try to disable it for moment
- Preferito
- Iscriversi
- Evidenziare
- Stampare
I am not using a VPN, nor is the firewall causing problems (tried all that before posting as a last resort).
Everything works well right up to where I click the click the arrow to download. It does nothing. I've disabled the ad blockers on the machines and OSs mentioned.
I went as far as spinning up a new stock Windows VM clone from a base VM image I have and the same behaviour occured.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Gordon,
I suspect that there is issue with the connection, is it still happen if you use different machine? (*not VM). For checking purpose, could you try to reboot your home router worst case try to use different connection let me know if works.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
I tried with two physical machines and two VMs. Same issue on all machines with various browsers (original post mentions the combinations I tried).
So far:
- Two physical machines and two VMs (three OSs and four browsers) exhibit the same behaviour.
- Disabled ad blocking and DNS blackhole.
- Tried new stock Windows VM with nothing added.
- Firewall twins and router reboot (unneccesary, but I was desperate).
- tcpdump on firewall's LAN interface has no traffic coming in when clicking the link.
- A direct link found elsewhere in the forums worked but that is for Windows.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Gordon,
Another workaround, have you tried to use different connection? If so, what is the result,able to download it?
- Preferito
- Iscriversi
- Evidenziare
- Stampare
I can't try another connection as I'm working from home and the work VPN has strict blocks for outside connectivity.
In any case, I managed to get a copy elsewhere.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Intel Support team,
I am having the exact same issue. I have tried from 2 different physical locations (in AU), with Chrome, Brave, Firefox, Safari, Edge (!). Adblocker on and adblocker off.
Attempts:
Linux : Pro : 20.1 - I get no reaction from the circular blue download button (combined files or individual files).
Windows : Pro : 20.1 - I get no reaction from the circular blue download button (combined files or individual files).
Linux : Lite : 19.1 - I get no reaction from the circular blue download button (combined files or individual files).
Windows : Lite : 19.1 - I get no reaction from the circular blue download button (combined files or individual files).
Windows : Lite : 18.1 - I get a "Legal Disclaimer" from the circular blue download button (combined files or individual files), but "I Agree" closes the disclaimer and nothing happens.
Windows : Pro : 18.1 - I get a "Legal Disclaimer" from the circular blue download button (combined files or individual files), but "I Agree" closes the disclaimer and nothing happens.
Linux: Pro : 14.0 - I get a "Legal Disclaimer" from the circular blue download button (combined files or individual files), but "I Agree" closes the disclaimer and nothing happens.
Any help is appreciated.
Iain
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Iain,
My suggestion is that to open new separate forum case since this case had been closed.
- Contrassegnare la discussione come nuova
- Contrassegnare la discussione come letta
- Sposta questo Discussione per l'utente corrente
- Preferito
- Iscriversi
- Pagina in versione di stampa
