Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1342 Discussions
I have this error message when i install QUARTUS II 12.1: Installer subprocess for quartus II web edition exited abnormally status code = 5.
RMoha28
KennyTan_Altera
May I know what OS that you were using for this installation?
RMoha28
KennyTan_Altera
Check if you are running under admin?
  1. Right-click on the .exe and choose "Properties."
  2. Then click the "Advanced" button at the bottom of the window that opens.
  3. Check "Run as Administrator".
RMoha28
i tried, but the problem not fixed
I have found the solution,
the solution is the internet connection must exist in installation
KennyTan_Altera
Good to know on that.
