We have code that programs .jbc file to the FPGA using a controller.
Everything works fine when the .jbc is compiled with Quartus v16.1
But it fails when it's compiled with any newer Quartus versions.
Any ideas on how this can be fixed? It's not very efficient to have multiple Quartus versions and keeping track which project needs to be compile with which version.
Thanks!
I would recommend you to manually generate the jbc file as this will let you have the option to enable the ISP programming mode.
連結已複製
I am generating the .jbc file automatically when doing compile by going:
Assignments -> Device -> Device and Pin Options -> Programming Files -> Check the Jam STAPL Byte Code 2.0 File.
I am not able to try the .sof file, because with our design, the only way to program is to use .jbc file.
If you look at the 2 zip files that I attached, you can see the error message (v16 works and v20 doesn't work).
