Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1343 Discussions
MAX 10 Development Kit EtherCAT and ADC
MiguelGarnelo
Hi!
I am interested on the MAX 10 FPGA products, specifically on the MAX 10 FPGA Development Kit and MAX 10 FPGA Evaluation Kit.
Regarding the Development Kit one, can the Ethernet ports be used for EtherCAT communication (of course getting the corresponding IP core from Beckhoff)?
Regarding the two kits, for analog-to-digital conversion (ADC), is it necessary to buy/get an ADC IP core, or does it come built-in when buying the kits?
Regarding the software, can be Quartus Pro used for both kits? And, can code be reused from one board to another (of course assigning the right pins)?
I hope you can solve my questions. Thank you!
Miguel Garnelo
AR_A_Intel
Hello
Welcome to INTEL forum. May we know, is this the board that you’re referring to?
https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/max-10-fpga-development-kit.html
MiguelGarnelo
Thanks for your answer!
Yes, that's the board I am interested in using.
AR_A_Intel
Hi
Thanks for update. Based on my understanding, you need to buy the IP core. Kindly contact your nearest Intel salesperson or distributor.
https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
And yes. The Ethernet ports be used for EtherCAT communication.
MAX 10 FPGA is not available in Quartus Pro. Refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/po/ss-quartus-comparison.pdf  For software, it is advice to use Quartus version 15 and above.
Regarding “can code be reused” Could you elaborate more what do you means?
MiguelGarnelo
Hi
Thanks again for your reply! Regarding the IP core you mention to buy is the one for ADC or the one from Beckhoff to use EtherCAT over an FPGA?
Regarding reusing the code, I was meaning using the code developed with the MAX 10 development board discussed in this thread in a self-designed board including a MAX 10 FPGA.
Thank you!
AR_A_Intel
Hi
The IP is regarding on ADC and based on my understanding, yes you can reuse the code developed with the MAX 10.
mistersinha
Nice answer
AR_A_Intel
Thanks for your update, hope all is well. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
MiguelGarnelo
Thanks for your reply, it has been really helpful!
Just as the last thing, could you provide a link or guide on how to acquire the ADC IP core? I have searched online but have not found anything
Thanks again!
Miguel
