Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1342 Discussions
Missed to generate ModelSim FEATURE in my license file
CasperChen
Recently, my license file was expired.  So, I went to re-generate  my license file again.  However, I found it generate the empty ModelSim FEATURE as follows in my license file:
# FEATURE START
# The following is a license file for the ModelSim
# FEATURE END
Then, I got failed to run ModelSim with the below Fatal License Error:
CasperChen
Right now, I can run ModelSim with the above new license file LR-083849.
I found that ModelSim needs the license file name used with MGLS_LICENSE_FILE/LM_LICENSE_FILE is as same as that used in "Quartus --> Tools --> license setup...".
Basically, the new license file generated with all features can fix the root cause.
AR_A_Intel
Hi
Welcome to Intel forum. Could you provide the license.dat file (old and new) for checking? Thanks
For privacy, reply/attach file in private message.
CasperChen
My license file is attached.  (NOTE:  My MAC string is masked by ZZZ... )
CasperChen
Sorry, I forgot to attach my old license file.  Please check it by the attached file.
CasperChen
Today, I tried to re-generate my license file.  The new license file was generated with all features compared to my old license file.  BUT, it still got failed to run ModelSim with the below Fatal License Error:
AR_A_Intel
Thanks for update. Could you provide the new license.dat for checking?
BTW, I have file ticket to IT team regarding this error and awaiting for feedback
CasperChen
Thanks.   The attachment is my new license file re-generated on today, and I still got failed to run ModelSim as below:
CasperChen
AR_A_Intel
Thanks for your update, hope all is well. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
