Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1343 Discussions
Modelsim Licensing on Ubuntu 18.04
NPani2
I have an Academic License for Intel Quartus Prime Standard Edition and Modelsim Intel edition. The license is not a floating license, but rather a single PC license.
I am able to run Quartus, compile the design and program the design to the FPGA,
However the Pro Version of Modelsim does not launch. I have installed the 32 bit libraries and made appropriate changes to the vsim script in the bin directory, but when I try to execute the script after changes I get this error
"Unable to find the license file. It appears that your license file environment variable (e.g., LM_LICENSE_FILE) is not set correctly.
Unable to checkout a license. Vsim is closing.
** Fatal: Invalid license environment. Application closing."
Anybody knows how to fix this licensing issue.
AR_A_Intel
Hello
Welcome to INTEL forum. May I know Quartus version you use?
NPani2
It is Quartys Prime Standard edition 18.1 . The license file generated is the .dat file fixed to a single computer. I am using the Terasic DE5 Net FPGA board. I am able to synthesize and program the design, but not able to run Modelsim due to the following issues.
AR_A_Intel
Could you help check and upgrade the client PC to newest version of alterad and Modelsim daemon v11.16.1 & 11.13.1.2 and try it.
The daemons can be downloaded from the following link:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/licensing/daemons.html
