連結已複製
Correct, Quartus Prime Pro 21.2.
Computer properties:
Processor Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz 3.70 GHz
Installed RAM 32.0 GB (31.9 GB usable)
Device ID 1070AA84-6CDE-4867-8B33-3BE254EE9131
Product ID 00331-20000-00000-AA109
System type 64-bit operating system, x64-based processor.
(Widows 10)
Screenshot:
Elit
Hi Nurina,
I was able to download not corrupted file, but only on a different computer with Internet Explorer,
not Google Chrome and not Microsoft Edge (Chromium).
But unfortunately there are problems with the license, generated by the link, specified during installation.
Attached screenshot, Mentor Graphics debug log, license file.
Perhaps the simulator requires a license with Host ID - MAC address, not GUARD_ID ?
If this is correct, please regenerate license - MAC address text file attached.
Thanks, Elit
Thank you Elit.
Did you set the environment variables? If not, go to Control Panel->System->Advanced System->Environment Variables
Then under user variables set a variable "Path" to have a value "C:\intelFPGA_pro\21.2\questa_fe\win64" it should look something like that, otherwise try looking for the questa win64 installation folder and use that path.
Let me know if this solves your problem.
Nurina
Hi Elit,
You are right, the license requires MAC ID instead of GUARD_ID for the host ID.
Regenerate your license here: https://fpgasupport.intel.com/Licensing/license/index.html?r=1617866734000&navi=8
Nurina
Hi Nurina,
With help of the support center - Non IPS Licensing (Case 00628017 has been created.)-
I succeeded to add New Computer with MAC address Host ID, but...
generated license (attached) is empty - contains only comments.
I will also continue to contact the License support.
Elit
Hi Elit,
I suggest you to re-open the IPS case (you can just leave a comment and it will re-open), because the application engineer assigned to you is responsible for issues like yours. Let them know that you have re-generated the license but it does not work for you.
Nurina
