Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1342 Discussions
Run a floating licence server on a Virtual Machine
SHard2
Hi
We are looking to setup the FLEXlm floating licence server on a virtual machine under windows server 2012r2 running hyperv.
Is this supported?
I had noticed that LMtools requires a hardware NIC ID rather than a virtual one. But are there any other potential problems we need to be aware of?
many thanks
Simon
AR_A_Intel
Hello
Welcome to INTEL forum. But before setting up your license, would you kindly help check whether your machine is supported or not (OS) by referring to link below:
https://www.altera.com/support/support-resources/download/os-support.html
Make sure the port used by license server or vendor daemon is not blocked. The port number is required for Windows systems and should be outside of the 27000-28000 range and be unique on the machine.
My suggestion would be:
1)     After VPN connection is established, setup license path in Quartus II>>tools>>license setup.
2)     Verify license server is running by using “lmutil lmstat –a –c <port>@<server> in BOTH server and client machine.
3)     Ping license server via VPN or telnet <host>< port> to chect the TCP connection is established
Please stop and restart the server. You need to allow the firewall access to the port number from both server and client machine.
You can also refer to link below for more detailed instructions for Setting up a floating network license server (page 32 of 59):
https://www.altera.com/content/dam/altera-www/global/en_US/pdfs/literature/manual/quartus_install.pdf
You can also refer this following YouTube for license setup. https://www.youtube.com/watch?v=Ob9ei5lMgGE
You can also refer to this following YouTube on Setting up and debugging Quartus floating licenses.
https://www.youtube.com/watch?v=llLaWatUbe8
Let me know if this information is helpful.
