Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1235 Discussions
How used MAX10 LVDS Serdes CDR
This is Doosoo Ha, senior engineer of Opticis.
I am designing a LVDS serdes system using two(2) of MAX 10 devices.
I plan to build LVDS serdes system as transmitting data with only one LVDS signal line.
The LVDS using in my system is "LVDS with embedded clock". In other words, a separate clock signal for LVDS deserialization is not transmitted. I set LVDS serialize as factor is ‘10’ and the data rate as ‘100Mbps’.
I confirmed LVDS output is normal when inputting K28.5 data to LVDS serialize block.
After that, I designed deserialize block to LVDS deserialize block but problem has occurred during its verification.
What it saying as a problem is that the clock was asynchronized during deserialization because it was designed with "without clock signal".
I would like to know if there is any way clock not being asynchronized when I use LVDS with embedded clock without transmitting a separate clock signal for LVDS deserialization.
Please assist me how I can solve this problem.
