Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1237 Discussions
Problem with Altera Monitor Program
Hi!
We try to run a simple Assembler program ( the Quartus II tutorial ) but when trying to download the program into the DE2 board, we get the following error-msg.
GDB ERROR: Error starting GDB debugger server. (java.lang.NullPointerException)
Any ideas?
/Andreas
I am having the same issue. I have quartus 10.0sp1 in win7 and using the Altera Monitor Program
I am using Quartus 10.1 /windows xp....
i tried downloading the AMP but i could find only one link which says for Quartus 9.0 and 9.1
Is there a separate version for 10.1 version ?
Also when i tried installing the AMP which i downloaded, i got an error saying i have to install NIOS II IDE but i have installed the same already
help..!
I solved my issue...it was connected back to my Quartus II design file....I had my pin assignments incorrect...once I fixed that, it loaded perfectly
...as for any versioning issues...I've been told there's an environment variable that may need set, but I don't have any direct experience with this issue
The AMP works well for me but loading a hex file is a problem since i coudnt sort a memory location and its address. How to proceed next?
