Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1235 Discussions
Problem with transferring data from different clock domains using dual_port_ram
Hello everyone,
I want to transfer a frame from 143Mhz clock domain to 49Mhz clock domain to view the frames through vga,
For a test i tried to transfer a vertical and horizontal white lines to view through the vga port. But i am not getting it right. What i expect is https://ibb.co/ink4qj . But what i am getting is https://ibb.co/i3hojd . I don't know what i have done wrong. I am stuck
here, If someone could help me, it would be great.
Thank you!
(All the VHD files are uploaded and the top level is "fifo.vhd". The board i am using is DE1-SoC)
“pll” entity is undefined in provided codes.
Have you checked the simulation by using test bench?
Let me know, if you need any further assistance.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
