Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
公告
1238 討論
Quartus Prime Lite Version 20.1.0 testbench
KILIC
初學者
2,942 檢視
Hi.
I have a problem generating the test bench, saying testbench_file option contains a non-existent directory path. What can I do?
Copy of the text: Error (199013)
Determining the location of the ModelSim executable...
Using: c:/intelfpga_lite/20.1/modelsim_ase/win32aloem/
To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options
Note: if both ModelSim-Altera and ModelSim executables are available, ModelSim-Altera will be used.
**** Generating the ModelSim Testbench ****
Error (199013): HDL output file name "C:/Users/... /simulation/qsim/output_files/Waveform.vwf.vht" used with --testbench_file option contains a non-existent directory path
Error: Quartus Prime EDA Netlist Writer was unsuccessful. 1 error, 1 warning
Error: Peak virtual memory: 4713 megabytes
Error: Processing ended: Thu May 19 12:55:01 2022
Error: Elapsed time: 00:00:02
Error: Total CPU time (on all processors): 00:00:02
0 積分
5 回應
SyafieqS
員工
2,933 檢視
Ahmet,
Can you verify the path of the testbench? Make sure the path name no space all that, alphanumeric type of name.
KILIC
初學者
2,924 檢視
Thank you. it worked, the spaces were the problems.
But I have a new Error. What does it mean?->
# ** Error (suppressible): (vsim-12110) The -novopt option has no effect on this product. -novopt option is now deprecated and will be removed in future releases.
# Error loading design
# End time: 11:13:26 on May 20,2022, Elapsed time: 0:00:01
# Errors: 1, Warnings: 0
quartus_eda --gen_testbench --tool=modelsim_oem --format=vhdl --write_settings_files=off LEDS -c LEDS --vector_source="C:/Users/Ilyas Cem KILIC/Desktop/VHDL/Projekt1/Waveform.vwf" --testbench_file="C:/Users/Ilyas Cem KILIC/Desktop/VHDL/Projekt1/simulation/qsim/Waveform.vwf.vht"
Info: *******************************************************************
Info: Running Quartus Prime EDA Netlist Writer
Info: Version 20.1.0 Build 711 06/05/2020 SJ Lite Edition
Info: Copyright (C) 2020 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and any partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details, at
Info: https://fpgasoftware.intel.com/eula.
Info: Processing started: Fri May 20 11:13:11 2022
Info: Command: quartus_eda --gen_testbench --tool=modelsim_oem --format=vhdl --write_settings_files=off LEDS -c LEDS --vector_source="C:/Users/Ilyas Cem KILIC/Desktop/VHDL/Projekt1/Waveform.vwf" --testbench_file="C:/Users/Ilyas Cem KILIC/Desktop/VHDL/Projekt1/simulation/qsim/Waveform.vwf.vht"
Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
Completed successfully.
**** Generating the functional simulation netlist ****
quartus_eda --write_settings_files=off --simulation --functional=on --flatten_buses=off --tool=modelsim_oem --format=vhdl --output_directory="C:/Users/Ilyas Cem KILIC/Desktop/VHDL/Projekt1/simulation/qsim/" LEDS -c LEDS
Info: Processing started: Fri May 20 11:13:16 2022
Info: Command: quartus_eda --write_settings_files=off --simulation=on --functional=on --flatten_buses=off --tool=modelsim_oem --format=vhdl --output_directory="C:/Users/Ilyas Cem KILIC/Desktop/VHDL/Projekt1/simulation/qsim/" LEDS -c LEDS
Info (204019): Generated file LEDS.vho in folder "C:/Users/Ilyas Cem KILIC/Desktop/VHDL/Projekt1/simulation/qsim//" for EDA simulation tool
Info: Quartus Prime EDA Netlist Writer was successful. 0 errors, 1 warning
Info: Peak virtual memory: 4715 megabytes
Info: Processing ended: Fri May 20 11:13:19 2022
Info: Elapsed time: 00:00:03
Info: Total CPU time (on all processors): 00:00:03
**** Generating the ModelSim .do script ****
C:/Users/Ilyas Cem KILIC/Desktop/VHDL/Projekt1/simulation/qsim/LEDS.do generated.
**** Running the ModelSim simulation ****
c:/intelfpga_lite/20.1/modelsim_ase/win32aloem//vsim -c -do LEDS.do
Reading pref.tcl
# 2020.1
# do LEDS.do
# Model Technology ModelSim - Intel FPGA Edition vcom 2020.1 Compiler 2020.02 Feb 28 2020
# Start time: 11:13:24 on May 20,2022
# vcom -work work LEDS.vho
# -- Loading package STANDARD
# -- Loading package TEXTIO
# -- Loading package std_logic_1164
# -- Loading package VITAL_Timing
# -- Loading package VITAL_Primitives
# -- Loading package dffeas_pack
# -- Loading package altera_primitives_components
# -- Loading package altera_lnsim_components
# -- Loading package cyclonev_atom_pack
# -- Loading package cyclonev_components
# -- Compiling entity LEDS
# -- Compiling architecture structure of LEDS
# End time: 11:13:24 on May 20,2022, Elapsed time: 0:00:00
# Errors: 0, Warnings: 0
# vcom -work work Waveform.vwf.vht
# -- Compiling entity LEDS_vhd_vec_tst
# -- Compiling architecture LEDS_arch of LEDS_vhd_vec_tst
# vsim -novopt -c -t 1ps -L cyclonev -L altera -L altera_mf -L 220model -L sgate -L altera_lnsim work.LEDS_vhd_vec_tst
# Start time: 11:13:25 on May 20,2022
Error.
KILIC
初學者
2,906 檢視
Hallo again.
I have tried to eliminate all blanks but the error stay. I was suspicious and changed even the computername without a blank but it referes still to the old name, even after deinstalling an installing again.
Here is the Error text :Error (199013):..
quartus_eda --gen_testbench --tool=modelsim_oem --format=vhdl --write_settings_files=off LEDS -c LEDS --vector_source="C:/Users/Ilyas Cem KILIC/Desktop/VHDL/Projekt1/output_files/Waveform1.vwf" --testbench_file="C:/Users/Ilyas Cem KILIC/Desktop/VHDL/Projekt1/simulation/qsim/output_files/Waveform1.vwf.vht"
Info: Version 20.1.1 Build 720 11/11/2020 SJ Lite Edition
Info: Processing started: Sat May 21 07:32:12 2022
Info: Command: quartus_eda --gen_testbench --tool=modelsim_oem --format=vhdl --write_settings_files=off LEDS -c LEDS --vector_source="C:/Users/Ilyas Cem KILIC/Desktop/VHDL/Projekt1/output_files/Waveform1.vwf" --testbench_file="C:/Users/Ilyas Cem KILIC/Desktop/VHDL/Projekt1/simulation/qsim/output_files/Waveform1.vwf.vht"
Error (199013): HDL output file name "C:/Users/Ilyas Cem KILIC/Desktop/VHDL/Projekt1/simulation/qsim/output_files/Waveform1.vwf.vht" used with --testbench_file option contains a non-existent directory path
Error: Peak virtual memory: 4711 megabytes
Error: Processing ended: Sat May 21 07:32:14 2022
Error.
SyafieqS
員工
2,875 檢視
Ahmet,
It means the option for this command had been removed. Thus the simulator cannot continue the flow as it is unknown command.
Removed the command that should be working.
SyafieqS
員工
2,849 檢視
We do not receive any response from you to the previous reply that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
回覆
