Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
Using TSE MAC+ 88e1111 PHY on De2i 150 board to send data between FPGA and PC
Hello everyone:
I'm now trying to use TSE MAC+ 88e1111 PHY on De2i 150 board to send data between FPGA and PC,which needs run at a speed at least 200Mbps.
Firstly,I used Terasic's Websever Demo which uses a Nichestack. But finally I found that it can only run at 100M ethernet mode.
Then I tried to write a simple C program not using Nichestack to send Udp data to my PC.But I don't know how to configure the Mac and PHY register.Can anybody give me some instruction?
I am not sure I understand what you are exactly trying to do, but this document (ftp://ftp.altera.com/up/pub/altera_material/15.0/tutorials/de2-115/using_triple_speed_ethernet.pdf)describes how to use the Ethernet on that board. here (ftp://ftp.altera.com/up/pub/altera_material/15.0/tutorials/de2-115/using_triple_speed_ethernet.zip)is also an example project.
I hope that helps you to solve your issues. Let me know, how it goes.
Cheers,
Fade
Thank you very much. I will have a try.
I have tried what you mentioned above. Firstly I used .sof file to configure my FPGA,which is similar to the document you mentioned above.Secondly,I copied the tse_tutorial.c file to my Nios II project, then I made some changes to fit my appliciation
volatile int * tse = (int *) 0x12042000;
printf("%x",*(tse + 2));
// Initialize the MAC address
*(tse + 3) = 0x116E6001;
*(tse + 4) = 0x00000F02;
// Specify the addresses of the PHY devices to be accessed through MDIO interface
*(tse + 0x0F) = 0x10;
//*(tse + 0x10) = 0x11;
// Write to register 20 of the PHY chip for Ethernet port 0 to set up line loopback
//*(tse + 0x94) = 0x4000;
// Write to register 16 of the PHY chip for Ethernet port 1 to enable automatic crossover for all modes
*(tse + 0x90) = *(tse + 0x90) | 0x0060;
// Write to register 20 of the PHY chip for Ethernet port 2 to set up delay for input/output clk
*(tse + 0x94) = *(tse + 0x94) | 0x0082;
// Software reset the second PHY chip and wait
*(tse + 0x80) = *(tse + 0x80) | 0x8000;
while ( *(tse + 0x80) & 0x8000 );
printf("PHY reset over");
But it seems that it failed to complete the Software reset the second PHY chip and wait . Can you tell me what i should solve this problem ?
I will try to help you, but first please list your used FPGA, the board (I assume it is the DE2-115 from Terasic) and the used software version.
Did you run the example project? Did it work? If you have not done that, can you please test that first?
I am asking for this because I would do exactly the same, before starting to modify it. As soon as I know if that is the board you are using I can give it a try myself.
Cheers,
hello,
I used De2i-150board from terasic which contains a cyclone IV FPGA inside, there is only one 88e1111 PHY. My software version if Quartus II 13.0.
I tried to run the example project ,But I need to do some changes first,the following is my code(difference with the example is only the registers configure )
# include <altera_avalon_sgdma.h>
# include <altera_avalon_sgdma_descriptor.h>
# include <altera_avalon_sgdma_regs.h>
# include "sys/alt_stdio.h"
# include "sys/alt_irq.h"
# include <unistd.h>
// Function Prototypes
void rx_ethernet_isr (void *context);
// Global Variables
unsigned int text_length;
// Create a transmit frame
unsigned char tx_frame[1024] = {
0x00,0x00, // for 32-bit alignment
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, // destination address (broadcast)
0x01,0x60,0x6E,0x11,0x02,0x0F, // source address
0x00,0x2E, // length or type of the payload data
'\0' // payload data (ended with termination character)
// Create a receive frame
unsigned char rx_frame[1024] = { 0 };
// Create sgdma transmit and receive devices
alt_sgdma_dev * sgdma_tx_dev;
alt_sgdma_dev * sgdma_rx_dev;
// Allocate descriptors in the descriptor_memory (onchip memory)
alt_sgdma_descriptor tx_descriptor __attribute__ (( section ( ".descriptor_memory" )));
alt_sgdma_descriptor tx_descriptor_end __attribute__ (( section ( ".descriptor_memory" )));
alt_sgdma_descriptor rx_descriptor __attribute__ (( section ( ".descriptor_memory" )));
alt_sgdma_descriptor rx_descriptor_end __attribute__ (( section ( ".descriptor_memory" )));
* This program demonstrates use of the Ethernet in the DE2-115 board.
* It performs the following:
* 1. Records input text and transmits the text via Ethernet after Enter is
* pressed
* 2. Displays text received via Ethernet frame on the JTAG UART
int main(void)
// Open the sgdma transmit device
sgdma_tx_dev = alt_avalon_sgdma_open ("/dev/sgdma_tx");
if (sgdma_tx_dev == NULL) {
alt_printf ("Error: could not open scatter-gather dma transmit device\n");
return -1;
} else alt_printf ("Opened scatter-gather dma transmit device\n");
// Open the sgdma receive device
sgdma_rx_dev = alt_avalon_sgdma_open ("/dev/sgdma_rx");
if (sgdma_rx_dev == NULL) {
alt_printf ("Error: could not open scatter-gather dma receive device\n");
return -1;
} else alt_printf ("Opened scatter-gather dma receive device\n");
// Set interrupts for the sgdma receive device
alt_avalon_sgdma_register_callback( sgdma_rx_dev, (alt_avalon_sgdma_callback) rx_ethernet_isr, 0x00000014, NULL );
// Create sgdma receive descriptor
alt_avalon_sgdma_construct_stream_to_mem_desc( &rx_descriptor, &rx_descriptor_end, (alt_u32 *)rx_frame, 0, 0 );
// Set up non-blocking transfer of sgdma receive descriptor
alt_avalon_sgdma_do_async_transfer( sgdma_rx_dev, &rx_descriptor );
// Triple-speed Ethernet MegaCore base address
// Enable read and write transfers, gigabit Ethernet operation, and CRC forwarding
*(tse + 2) = *(tse + 2) | 0x0000004B;
alt_printf( "send> " );
text_length = 0;
while (1) {
char new_char;
tx_frame[16] = '\0';
// Add new typed characters to the transmit frame until the user types the return character
while ( (new_char = alt_getchar()) != '\n' ) {
if (new_char == 0x08 && text_length > 0) { // Check if character is a backspace and if there is anything
to delete
alt_printf( "%c", new_char );
text_length--;
// Maintain the terminal character after the text
tx_frame[16 + text_length] = '\0';
} else if (text_length < 45) { // Check if there is still room in the frame for
another character
// Add the new character to the output text
tx_frame[16 + text_length] = new_char;
text_length++;
alt_printf( "\nsend> " );
text_length = 0;
// Create transmit sgdma descriptor
alt_avalon_sgdma_construct_mem_to_stream_desc( &tx_descriptor, &tx_descriptor_end, (alt_u32 *)tx_frame, 62, 0, 1, 1, 0
// Set up non-blocking transfer of sgdma transmit descriptor
alt_avalon_sgdma_do_async_transfer( sgdma_tx_dev, &tx_descriptor );
// Wait until transmit descriptor transfer is complete
while (alt_avalon_sgdma_check_descriptor_status(&tx_descriptor) != 0)
return 0;
* Subroutine to read incoming Ethernet frames
int i;
// Wait until receive descriptor transfer is complete
while (alt_avalon_sgdma_check_descriptor_status(&rx_descriptor) != 0)
// Clear input line before writing
for (i = 0; i < (6 + text_length); i++) {
alt_printf( "%c", 0x08 ); // 0x08 --> backspace
// Output received text
alt_printf( "receive> %s\n", rx_frame + 16 );
// Reprint current input line after the output
alt_printf( "send> %s", tx_frame + 16 );
// Create new receive sgdma descriptor
I don't whether I have made you understand my problem.
Hi sorry I did not have anything new on your issue. I did not have the time to take a close look at it. As soon as I have something I let you know.
