Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
Объявления
1238 Обсуждение
Verilog code for a clock
Почетный участник II
4 029Просмотр.
I'm new to writing code. I'm currently working on code for a clock... a pretty standard homework application for students I know. I've been trying to teach myself verilog for sometime now, and I could some guidance.
Here's part of my code for the hour part of the clock. It takes clock input that's already down to the proper timing. I'm trying to get the code to count up to 12 then reset down to 0. The outputs A and B go to a 7 segment driver, and I'm using C to count to 12 and reset. But there's obviously something wrong or I wouldn't be asking. Thanks in advance.
-Drew
module decimal_counter_20(A,B,CLK,RST);
input CLK, RST;
output [3:0] A;
output [3:0] B;
reg [3:0] A;
reg [3:0] B;
reg [4:0] C;
always @ (posedge CLK or negedge RST)
if (~RST)begin
A <= 4'b0000;
B <= 4'b0000;
C <= 5'b00000;
end
else if (B < 9)begin
B = B + 4'b0001;
C = C + 5'b00001;
end
else if (B == 9)begin
A = A + 4'b0001;
B <= 4'b0000;
end
else if (C > 12)begin
A <= 4'b0000;
B <= 4'b0000;
C <= 5'b00000;
end
endmodule
0 баллов
2 Ответы
1 039Просмотр.
Have you simulated your design? If you have, you would easily see the problem.
I can't match your code with what you describe.
As I understand, CLK is the hour clock, and you want to use this clock to count from 0 to 12 in a BCD sequence and display the result on two 7-segment LEDs as the hour, right?
I would do it as the following:
input CLK, RST;
output [3:0] A; // suppose A is the higher digit of hour counter
output [3:0] B; // suppose B is the lower digit of hour counter
reg [4:0] C; // hour counter from 0 ("00000")to 12 ("10010") in BCD sequence
if (~RST)
C <= 5'b00000;
else
if (C == 5'b10010)// count to 12, reset to 0
C <= 5'b00000;
else
if(C[3:0] == 4'b1001) //when lower digit reaches 9
begin
C[3:0] <= 4'b0000; //lower digit resets to 0
C[4] <= 1'b1; //higher digit becomes 1
end
else
C[3:0] <= C[3:0] + 4'b1; // increase by 1
//assign the lower digit of counter to B
assign B = C[3:0];
//A can only be either 0 or 1, so A[3:1] are always 0
assign A[0] = C[4];
assign A[3:1] = 3'b000;
endmodule
1 039Просмотр.
Genius...
So you use C as the count... than assign A and B as outputs to the count. That makes much more sense. Its a slow learning process. Thanks for the help.
-D
Ответить
