Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
Has anyone here had any problem using the DE2_70_control_panel.exe, file came with the DE2_70 dev. board? I am using Quartus II 10.0 web version and
Nios II EDS 10. Whenever I try to launch the DE2_70_control_panel.exe, as instructed in chapter 3 of the users manual, the following error message pops up: "The program can't start because jtag_client.dll is missing from your computer. Try reinstalling the program to fix this problem." "Load DLL (TERASIC_JTAG_DRIVE.dll) fail" "Fail to connect to FPGA board" I 'm not sure what these are about, but I know I was able to download the provided sof file to the FPGA via USB-blaster. Can anyone show me how to correct this problem? Thanks!Link Copied
In fact, I do not have a solution for your problem. but I have some problem in downloading the .sof file. when I click on the buttom "Download Code" it gives me the message "Make sure that Quartus software is installed on your PC"... I have QuartusII 9.1 installed....
any help? Best,After a whole lot of digging I was able to figure out what the problem was. I had to do two things:
1) Copy over jtag_client.dll and dinkum_alt.dll from "QUARTUS_ROOT_DIR\quartus\bin" to the Control Panel software folder. 2) Add the following two directories to my windows system PATH variable: C:\altera\10.0\nios2eds\bin C:\altera\10.0\nios2eds\bin\nios2-gnutools\H-i686-pc-cygwin\bin Step 1 was courtesy of Terasic's tech support and has now been added to their technical FAQ webpage. Step 2 I figured out on my own and essentially consisted of having to go through each script and running them all manually until I figured out where they were failing. I have no idea why it is that some people have to do this fix and some people don't. Some people have no problems at all. Weird. Just FYI, my system is Windows 7 64-bit running Quartus and NIOS II EDS v10.0. Hope this helps someone in the future. Pz! Jonathon--- Quote Start --- 2) Add the following two directories to my windows system PATH variable: C:\altera\10.0\nios2eds\bin C:\altera\10.0\nios2eds\bin\nios2-gnutools\H-i686-pc-cygwin\bin --- Quote End --- I don't understand the step 2 that you mentioned. Can you give more detail how you do it?
and run DE2_70_control_panel.exeHere are some videos on how to change your PATH variable:
XP: http://www.youtube.com/watch?v=vaqk8o5nu4g Win 7/Vista: http://www.youtube.com/watch?v=t1kbuamqljyhasil86,
I still have the problem after I copy the jtag_client.dll and dinkum_alt.dll. So I have to do the second step from jwdonal. I think it depends. Some people already solved the problem by just copy that two things, some people still have problem.I still don't understand how to edit the path variable. How to add or edit both of the directories you mentioned before to the PATH variable? as I see in youtube, its seems that we can only add or edit one directory to the PATH variables.
--- Quote Start --- After a whole lot of digging I was able to figure out what the problem was. I had to do two things: 1) Copy over jtag_client.dll and dinkum_alt.dll from "QUARTUS_ROOT_DIR\quartus\bin" to the Control Panel software folder. 2) Add the following two directories to my windows system PATH variable: C:\altera\10.0\nios2eds\bin C:\altera\10.0\nios2eds\bin\nios2-gnutools\H-i686-pc-cygwin\bin Step 1 was courtesy of Terasic's tech support and has now been added to their technical FAQ webpage. Step 2 I figured out on my own and essentially consisted of having to go through each script and running them all manually until I figured out where they were failing. I have no idea why it is that some people have to do this fix and some people don't. Some people have no problems at all. Weird. Just FYI, my system is Windows 7 64-bit running Quartus and NIOS II EDS v10.0. Hope this helps someone in the future. Pz! Jonathon --- Quote End --- After digging until exaustion I finally put Control Panel to work under Quartus and NIOS II EDS v10.1 and Windows 7 x32. In my case I needed to follow the two first steps indicated by Jonathon. Then, using Quartus II, download the DE2_70_Control_Panel.sof. The last step was using a batch file that comes in the CD NiosDownloadBatch.bat Execute the Control Panel. Without the system PATH change, the batch file would fail to find the NIOS gdb and some other file ... Thanks Jonathon!
Just wanted to mention that these steps worked for the DE4 board too. No need to download the .sof before launching the control panel, though.
Attached you can find how to add a path to the variable, just use a semicolon ; to add a new path to the existent.Thanks so much, jwdonal. That guide worked perfectly. I was having quite a headache from this.
I had the same problem and I could solve whith your first step. But when I run the Control Panel it shows a massanger "Please make sure Quartus is instaled". Also I can't download any descriptions to the board, everytime I do programing it fails.
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
For more complete information about compiler optimizations, see our Optimization Notice.
