Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
intelFPGA Monitor Program not connecting [DE1-SoC]
I'm following the tutorial on the intelFPGA monitor program for the DE1-SoC Arm 9 core, and I'm using the sample DE1-SoC Computer program with sample program JTAG Uart demonstration. However, the board will not connect using semihosting, or any other program for that matter.
Error message reads Could not query JTAG Instance IDs.Please ensure the FPGA has been configured using the correct .sof file.
It's the correct .sof file, even tried manually connecting using the GUI button to connect, still of no avail.
I tried the NIOS II program and everything runs fine.
Why can it not communicate?
It's set to the cpu0- core and not the one that powers up in reset.
^^Bump
Here is the error code
C:/altera_lite/16.0/quartus/bin64/quartus_pgm -c "DE-SoC [USB-1]" --auto
1) DE-SoC [USB-1]
4BA00477 SOCVHPS
02D120DD 5CSE(BA5|MA5)/5CSTFD5D5/..
Info: *******************************************************************
Info: Running Quartus Prime Programmer
Info: Version 16.0.0 Build 211 04/27/2016 SJ Lite Edition
Info: Copyright (C) 1991-2016 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, the Altera Quartus Prime License Agreement,
Info: the Altera MegaCore Function License Agreement, or other
Info: applicable license agreement, including, without limitation,
Info: that your use is for the sole purpose of programming logic
Info: devices manufactured by Altera and sold by Altera or its
Info: authorized distributors. Please refer to the applicable
Info: agreement for further details.
Info: Processing started: Tue Sep 26 12:32:00 2017
Info: Command: quartus_pgm -c "DE-SoC [USB-1]" -m jtag -o P;../Computer_Systems/DE1-SoC/DE1-SoC_Computer/verilog/DE1_SoC_Computer.sof@2
Info (213045): Using programming cable "DE-SoC [USB-1]"
Info (213011): Using programming file ../Computer_Systems/DE1-SoC/DE1-SoC_Computer/verilog/DE1_SoC_Computer.sof with checksum 0x0ADD8F95 for device 5CSEMA5F31@2
Info (209060): Started Programmer operation at Tue Sep 26 12:32:02 2017
Info (209016): Configuring device index 2
Info (209017): Device 2 contains JTAG ID code 0x02D120DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Tue Sep 26 12:32:05 2017
Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 284 megabytes
Info: Processing ended: Tue Sep 26 12:32:05 2017
Info: Elapsed time: 00:00:05
Info: Total CPU time (on all processors): 00:00:02
ARM_A9_HPS_arm_a9_0 will be halted upon running the preloader. Skip halting.
ARM_A9_HPS_arm_a9_1 will be halted upon running the preloader. Skip halting.
Halting operation timed out while halting Nios2
Failed to halt Nios2
Halting operation timed out while halting Nios2_2nd_Core
Failed to halt Nios2_2nd_Core
Info: Processing started: Tue Sep 26 12:32:45 2017
Info: Command: quartus_hps --cable="DE-SoC [USB-1]" -o GDBSERVER --gdbport0=2530 --preloader=C:/altera_lite/16.0/University_Program/Monitor_Program/arm_tools/u-boot-spl.srec --preloaderaddr=0xffff13a0
Current hardware is: DE-SoC [USB-1]
Successfully change hardware frequency to 16Mhz
Found HPS at device 1
Double check JTAG chain
HPS Device IDCODE: 0x4BA00477
AHB Port is located at port 0
APB Port is located at port 1
Double check device identification ...
>>CPU0 halted at 0x3ff82818.
>>Resetting HPS.
>>Downloading preloader.....
>>Program loaded. PC set to program entry (0xFFFF0000)
>>Setting vector base address register to: 0xffff0000
Timed out while waiting for preloader to finish
Preloader failed to run. HPS components may not have been configured.
Possible causes for the failure:
1. Linux SD card is inserted and Linux is running.
2. FPGA-side components are accessing HPS memory.
arm-altera-eabi-gcc -g -O1 -mfloat-abi=soft -march=armv7-a -mtune=cortex-a9 -mcpu=cortex-a9 -Wall -Wl,--defsym -Wl,arm_program_mem=0x0 -Wl,--defsym -Wl,arm_available_mem_size=0x3ffffff8 -Wl,--defsym -Wl,__cs3_stack=0x3ffffff8 -T"C:/altera_lite/16.0/University_Program/Monitor_Program/build/altera-socfpga-hosted.ld" -o "C:/Users/Owner/Documents/semihosting_example.axf" "C:/Users/Owner/Documents/semihosting_example.c"
ELF generated at C:/Users/Owner/Documents/semihosting_example.axf.
cd C:/Users/Owner/Documents ; arm-altera-eabi-objcopy -O srec semihosting_example.axf semihosting_example.srec
SREC generated at C:/Users/Owner/Documents/semihosting_example.srec.
Info: Processing started: Tue Sep 26 12:35:06 2017
Info: Command: quartus_hps --cable="DE-SoC [USB-1]" -o GDBSERVER --gdbport0=2608 --preloader=C:/altera_lite/16.0/University_Program/Monitor_Program/arm_tools/u-boot-spl.srec --preloaderaddr=0xffff13a0 --source=C:/Users/Owner/Documents/semihosting_example.srec
Hardware frequency: 16000000
Warning: Not able to halt CPU 0
Error: DBGDSCR fails to go to expected value
Error: Fail to write DEBUG INSTRUCTION
Error: Fail to read CPU Register
Error: Failed to read r15
>>CPU0 halted at 0xfffffff8.
>>Resetting HPS.
>>Downloading preloader..Error: DBGDSCR fails to go to expected value
Error: Fail to write 2048 of DWORD(s) to address 0xFFFF0000 through CPU 0
Error: Failed to write 2048 words to 0xffff0000. Loading SREC failed.
>>Downloading user program.Error: DBGDSCR fails to go to expected value
Error: Fail to read CPU Register Stall Mode
Error: Fail to read 1 of DWORD(s) from address 0x00000007 through CPU 0
Error: Failed to load program.
Error: Sticky Error: 1
Error: Quartus Prime Programmer was unsuccessful. 0 errors, 0 warnings
Error: Peak virtual memory: 117 megabytes
Error: Processing ended: Tue Sep 26 12:35:21 2017
Error: Elapsed time: 00:00:15
Error: Total CPU time (on all processors): 00:00:03
I got the exactly same error, could not solve it after trying everything I can think of.
Did you make it work eventually?
I am stuck with the same issue now.
Were you able to solve this?
JJian21
I have the same issue, did you fix this problem?
Btw, I cannot find the .sof file in my testing folder, where could you find it?
