Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
writing 24bit-bmp file to SD Card on DE2
Hi, I use university program to read/write 24bit-bmp file to/from SD Card on DE2 board.
I want to do it. But, .bmp is binary file format.
Up to now, I 've read/written to/from SD card at .dat file format.
I have a question,
Do the HAL functions support binary file format?
I've solved the problem by myself.
Thank you.
hi!
I'm trying to write to a .txt file using the SD Card IP from altera, my board is lso the DE2 board.
I can write files to it however, when I write large data to it, I can no longer read them in the computer. What can I do?
hi, i utilize alt_up_sd_card ip on my de2-70 board for sd writing, but there always shows error information when i try to open a file in the sd card. could you give me some advice, 3k you
can u tell me hw to read an image stored in SD card with DE1 board?
@nonsuger Can you please post the steps of doing this?
Hello nonsuger, I am having the same problem, can you help?
Managed to read and write to the SD card, but not sure about .bmp format
http://www.alteraforum.com/forum/showthread.php?t=34101
