Dear all:
Recently, i try to use openmp language through the Intel Visual Fortran.
Because i am a beginner of the parallel computing, i decided to make the do-loops faster by using multiprocessor.
I read a lot of information about the openmp, but had this warning when compiling.
warning #10247: explicit static allocation of locals specified, overriding OpenMP*'s implicit auto allocation
I really don't know where the problem is.
If there are any suggestion, please help me.
Thank you very much
--------------------------------part of my program------------------------------------------------
!$omp parallel do default(shared) private(k,d_epsc,cgmci,Eta1)
do k = 1,nsteel(i) !the half of the section
d_epsc=dd_defN(m)-zz_steel(k,i)*dd_defMy(m)+
+ yy_steel(k,i)*dd_defMz(m)
call FrontSteel(i,Fiber,Fbmat,d_epsc,cgmci,k,m,nsm,
+ Eta1,time,repet,kfc,istep,nskip,secfail,ff_change)
! computing axial force and bending moment of each fiber of the section
f11(k) = cgmci*aa_steel(k,i)
fmy(k) = -cgmci*zz_steel(k,i)*aa_steel(k,i)
fmz(k) = cgmci*yy_steel(k,i)*aa_steel(k,i)
! summation of axial force and bending moment of all fibers of the section
ss_sum11 = ss_sum11 + f11(k)
ss_sum21 = ss_sum21 + fmy(k)
ss_sum31 = ss_sum31 + fmz(k)
f11(k)=0.
fmy(k)=0.
fmz(k)=0.
d_epsc=0.
end do
!$omp end parallel do
I am guessing you are not using IMPLICIT NONE, if not, please add that to the top of your subroutine (then fix the declarations).
A second issue you have is the summations are going to have data races
!$omp parallel do default(shared) private(k,d_epsc,cgmci,Eta1) reduction(+:ss_sum11, ss_sum21, ss_sum31)
The reduction clause for operator +, provides for a private copy of the named variables, each zeroed, for use within the parallel region. On exit from the parallel region the operator + is performed in a thread safe manner to the shared variable in the scope outside the parallel region.
Jim Dempsey
連結已複製
Jim Dempsey
I suspect you have explicitly set the /Qsave (Fortran->Data->Local Variable Storage = All Variables SAVE) compiler option.
The warning is output because /Oopenmp implies /Qauto (Local Variable Storage = Local Variables AUTOMATIC).
Dear Mr. Jim Dempsey
Thank you very much. Actually, i use IMPLICIT REAL*8 not the IMPLICIT NONE like you mentioned. I'll fix it immediately.
As about the data races condition, i am afraid that i didn't notice this problem. Once again, thank you very much.
I'll follow your suggestion to modify my program.
Pemg-Yu Chen
Dear Mr.Mark Lewy
Thank you very much. Just like you mentioned, i used the /Qsave (Fortran->Data->Local Variable Storage = All Variables SAVE) compiler option.
After change to the Local Variables AUTOMATIC , there is no any warning.
Pemg-Yu Chen
Dear all
I have another problem when i try to assign the number of threads.
I used "CALL omp_set_num_threads(4)" before the parallel region.
I also used the "USE omp_lib" at the head of my program.
There is an error message.
error LNK2019: unresolved external symbol omp_set_num_threads referenced in function_Main
please give me some suggestion.
Thank you very much
Check if you have /Qopenmp (Fortran->Language->Process OpenMP Directives = Generate Parallel Code) set for the build configuration that produces LNK2019. For example, if you set /Qopenmp for the Debug configuration only, you will also need to set it for the Release configuration (or use the All Configurations option for Configuration to set options that apply to all configurations).
Dear Mr. Mark Lewy
Yes, i already use the All Configurations option to set Fortran->Language->Process OpenMP Directives = Generate Parallel Code.
However, i still have the error message.
Pemg-Yu Chen
Dear Mr. Mark Lewy
Here are the command line settings for fortran:
/nologo /debug:full /Od /Qsave /iface:cvf /module:"Debug/" /object:"Debug/" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /dbglibs /c
and the command line settings for linker:
/OUT:"Debug/20100619_n_15_3D_10_CYW6.exe" /INCREMENTAL /NOLOGO /MANIFEST /MANIFESTFILE:"C:\Users\SAM\Desktop\Parallel(origion)\Debug\20100619_n_15_3D_10_CYW6.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"Debug/20100619_n_15_3D_10_CYW6.pdb" /STACK:100000000,100000000 kernel32.lib
Thank you very much
I can't see /Qopenmp in your Fortran settings. It looks like you switched OpenMP off to remove the warning about the clash with /Qsave which means the OpenMP library doesn't get pulled in when you link, hence the unresolved symbol.
Dear Mr. Mark Lewy
I set again the Fortran->Language->Process OpenMP Directives = Generate Parallel Code, but it still has the error message.
/nologo /debug:full /Od /Qopenmp /Qsave /iface:cvf /module:"Debug/" /object:"Debug/" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /dbglibs /c
Thank you very much
Is your call to omp_set_num_threads in the MAIN program, or in a subroutine called by the MAIN program?
The "use omp_lib" statement needs to be in the same program unit that is making the call to omp_set_num_threads. It is not enough to put it in the MAIN program when a different subroutine is making the call.
Also, if you could show the exact error message that might be helpful too. I was able to reproduce a failure when I removed the "use omp_lib" statement from my tiny program, but the error message was this one:
error LNK2019: unresolved external symbol _OMP_SET_NUM_THREADS@4 referenced in function _MAIN__
--Lorri
Write a simple program, see if it works, then look at what is different or same.
program foo use omp_lib implicit none !$omp parallel write(*,*) omp_get_thread_num() !$omp end parallel call omp_set_num_threads(4) !$omp parallel write(*,*) omp_get_thread_num() !$omp end parallel end program foo
Jim Dempsey
Dear Miss Lorri Menard
Yes, I call the omp_set_num_threads in a subroutine called by the MAIN program, and i only put "USE OMP_LIB" in the main program.
After following your suggestion to put the "USE OMP_LIB" in the subroutine, there is no any error message.
Thank you very much
Pemg-Yu Chen
Dear Mr.Jim Dempsey
Yes, i wrote the program that you suggested, it did work.
There is no any error message after following the suggestion of Miss Lorri Menard.
Pemg-Yu Chen
I'll assume you resolved the reduction bug which Jim pointed out.
Growth of stack usage is a frequent aspect of parallelization, even when you set a reasonable value for OMP_NUM_THREADS. By default, if HyperThreading is detected, the number of threads will be set to 2 per core, even though that is likely to be excessive (unless your only goal is to max out the meter graph). Note Jim's advice to start with a reasonable value.
Requirement to set the stack limit (by /link /stack: option or by editbin) is not surprising.
If you are using 32-bit mode, OMP_STACK_SIZE is preset to 2MB (4MB in 64-bit mode). That's the local stack per thread. Evidently, there are more limitations in parallel scaling in 32-bit mode.
Dear all:
Thank for your suggestions. I tried to modify my program by following Mr.Jim and Mr.Tim Prince.
However, I still had some problem.
If i didn't define the Stack Size, it will show the error "Stack Overflow".
If I defined a big number as the stack size, it still can't run.
I can't explain the problem exactly, so i updated some picture and the subroutine.
Thank you very much for your suggestions.
Pemg-Yu Chen
