I took the sample vectorization code matrix_vector_multiplication_f and modifed it a little to use allocatable memory. Then I compiled the code using two options: 1) /QxSSE4.2 and /QaxAVX; 2) /QxSSE4.2 and ran both on E5-2690. I was expecting for the single precision an 8x peak performance improvement with AVX and a 4x improvement with SSE4.2 by vectorization. But the results I got didn't match my expection. I observed 4x using SSE comparing to novec version but only <5x speedup for AVX. Did I miss anything?
I used Fortran compiler XE 13.0.1.119 and Visual Studio 2008 Version 9.0.30729.1 SP. The OS is Windows Server 2008 R2 Standard SP1. 32-byte alignment and ipo are applied. The baseline is compiled with -O1 and vectorized versions are compiled using -O3. I also varied the number of columns of the array and noticed performance drops as the total data size reaches 32KB and 256KB. I guess that is due to L1 and L2 cache miss. Is it correct?
链接已复制
Matrix multiplication is an ideal application for demonstration of AVX performance. It depends strongly on tiling for L1 locality, thus the renewed emphasis on performance libraries such as MKL.
You may notice with -O3 compilation that the Intel Fortran could perform automatic unroll-and-jam transformation so as to reduce the number of data reads and writes, but will not do so as aggressively as the MKL library code. In my experience, the MKL should begin to show an advantage as early as the case of minimum dimension 32.
