-CB finds issues where everything works as inteded?
Robin_T_
when I run the following program
program testbounds
	implicit none
	REAL, DIMENSION (5,5) :: A
	INTEGER, DIMENSION (2) :: K = (/ 1, 3 /)
	A = 0.d0
	A (2, (/1, 3, 5/)) = 1.d0
	print*, A
	print*, A (2, K)
end program testbounds
without check options it runs fine and delivers the desired result. When i use compiler option -CB I get
forrtl: severe (408): fort: (3): Subscript #2 of the array A has value 0 which is less than the lower bound of 1
Image              PC                Routine            Line        Source
testbounds.x         0000000000404E66  Unknown               Unknown  Unknown
testbounds.x         0000000000402D84  MAIN__                      9  testbounds.f90
testbounds.x         0000000000402B9E  Unknown               Unknown  Unknown
libc-2.22.so       00002B2D3557A6E5  __libc_start_main     Unknown  Unknown
testbounds.x         0000000000402AA9  Unknown               Unknown  Unknown
This is a bit strange to me and annoying because it prevents the use of -CB to find the real errors.
jimdempseyatthecove
What version of ifort are you using?
Jim Dempsey
Steve_Lionel
The behavior I see is an access violation/segfault, but I think it's just another symptom of the underlying compiler bug in that it is looking in the wrong place for the vector subscript bounds.  I am sure one of the Intel folks will be along to write this up for development.
Kevin_D_Intel
Thank you for the convenient reproducer. I too can reproduce this. On Linux, when run repeatedly I see either a SegV or a forrtl bounds error similar to what is shown in the original post. I escalated the issue to Development.
(Internal tracking id: DPD200418047)
FortranFan
Kevin,
Do you think this is related to the vector-subscript issue noticed in this recent thread?  Thanks,
https://software.intel.com/zh-cn/comment/1895746
Kevin_D_Intel
It might FortranFan. I made a note in the internal report about that.
jimdempseyatthecove
FWIW
program testbounds
 implicit none
 A = 0.d0
 print*, A
 print*, (A(2, K)) ! add ()'s
Jim Dempsey
Robin_T_
Thanks for all your comments.
I forgot to mention that I am using ifort version 17.0.1 on Linux 4.4.21-81-default x86_64
Adding the brackets, as proposed by Jim, works in that case but in the more complicated case:
program testbounds
  INTEGER, DIMENSION (2) :: K = [1, 3]
	A = 0.d0
	A (2, [1, 5]) = 1.d0
	A (2, 3) = 2.d0
	open (13, status = 'scratch')
	write (13, *) (A (2, [3, 5]))
	read (13, *) (A (3, [3, 5]))
	close (13)
	print *, A
this does not help either:
ifort -m64 -fpp -fopenmp -O3 -g -traceback -CB -c testbounds.f90
ifort testbounds.o -m64 -fpp -fopenmp -O3 -g -traceback -CB -o testbounds.x
forrtl: severe (408): fort: (2): Subscript #2 of the array A has value 32767 which is greater than the upper bound of 5
testbounds.x       0000000000406836  Unknown               Unknown  Unknown
testbounds.x       0000000000402C59  MAIN__                     11  testbounds.f90
testbounds.x       0000000000402A9E  Unknown               Unknown  Unknown
libc-2.22.so       00002B9CD779C6E5  __libc_start_main     Unknown  Unknown
testbounds.x       00000000004029A9  Unknown               Unknown  Unknown
So it works for write but not for read
jimdempseyatthecove
Robin,
The PRINT works because a temporary variable is created. A little overhead traded off against a bug fix.
For the READ, you do want to read into a temporary variable (which would be discarded had it worked).
I was going to suggest using associate, but this appears to expose a compiler bug (at least I think it is a bug)
program testbounds
 implicit none
 A = 0.d0
 A (2, 3) = 2.d0
    associate( slice => A (2, [3, 5]))
   write (13, *) slice
      slice = 0.0
      rewind(13)
   read (13, *) slice
    end associate
    close (13)
 print *, A
1>C:\test\testbounds\testbounds\testbounds.f90(19): error #6421: This scalar or array name is invalid in this context.   [SLICE]
Can someone explain why this does not work?
Jim Dempsey
Juergen_R_R
Valued Contributor II
jimdempseyatthecove wrote:
program testbounds
 implicit none
 A = 0.d0
 A (2, 3) = 2.d0
   write (13, *) slice
      slice = 0.0
      rewind(13)
   read (13, *) slice
    end associate
    close (13)
 print *, A
Jim Dempsey
associate-name => selector.  The standard says that if the selector is a variable with a vector subscript, the associated name must not appear in a variable definition context. e.g. Fortran Handbook, Sec. 8.2.1. A(2, 3:5) would work, than it's an array slice, not a vector subscript.
