COARRAYs
Václav_H_
Principiante
1.000 Vistas
 I have re-instaled the system in my computer.
 Afterwards some problems with my codes, which are using the COARRAYs, have appered. I have also found the problem during the runnig the coarray example. The picture is attached.
Thank you for any respond
The version of the compiler:
Intel(R) Visual Fortran Composer XE 2013 SP1 Update 4 Integration for Microsoft Visual Studio* 2010, 14.0.0100.2010
0 kudos
4 Respuestas
Steven_L_Intel1
Empleados
1.000 Vistas
Please click the START button, type "cmd" in the search field, and then click on cmd.exe. In the window that appears, type "set path". Copy the output and paste it into a reply here.
My guess is that you have some MPI other than Intel MPI in PATH.
Václav_H_
Principiante
1.000 Vistas
Thank you for your respond, here it is:
Path=C:\Program Files\Microsoft HPC Pack 2008 R2\Bin\;C:\Program Files (x86)\Com
mon Files\Microsoft Shared\VSA\10.0\VsaEnv;C:\Program Files (x86)\Common Files\I
ntel\Shared Libraries\redist\intel64\mpirt;C:\Program Files (x86)\Common Files\I
ntel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common File
s\Intel\Shared Libraries\redist\ia32\mpirt;C:\Program Files (x86)\Common Files\I
ntel\Shared Libraries\redist\ia32\compiler;C:\oh_11\client\bin;C:\orant\bin;O:\a
pld60\com;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\Sys
tem32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Common Files\Roxio Shared\D
LLShared\;C:\Program Files (x86)\Common Files\Roxio Shared\10.0\DLLShared\;C:\or
ant\jdk\bin;C:\Abaqus\Commands
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
Václav_H_
Principiante
1.000 Vistas
I just change the order in my PATH for having the \mpirt as the first and everything works.
Many thanks for the prompt reply
Steven_L_Intel1
Empleados
1.000 Vistas
Yes - you have the Microsoft MPI first on PATH and that doesn't work with our coarrays.
Responder
