Coarray - Internal compiler error / Wrong results
Jan_W_2
Compiling this program with ifort version 15.0.1 gives me:
testarray.f90: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for testarray.f90 (code 1)
Here is the code:
module test
  implicit none
  contains
  function sum_assumedshape(input, length) result(output)
   complex, dimension(:), intent(in)  :: input
  •    complex            :: output
       integer, intent(in) :: length
       integer :: i
       output = cmplx(0.0, 0.0)
       do i = 1, length
          output = output + input(i)
       end do
      end function
      function sum_assumedsize(input, length) result(output)
       complex, dimension(length), intent(inout)  :: input
  •    complex                     :: output
       integer :: i
       do i = 1, length
       end do
      end function
    end module
  • program sizevsshape
      use test
      implicit none
      complex, allocatable, dimension(:) :: in[:]
      complex                            :: out
      integer  :: i
      integer, parameter :: length = 4
      allocate(in(length)
      in = (/(cmplx(real(i),0.0), i=1, length)/)
      if(this_image() == 1) write(*,*) in
      out = sum_assumedshape(in, length)
      if(this_image() == 1) write(*,*) out
      out = sum_assumedsize(in, length)
  •   if(this_image() == 1) write(*,*) out
    end program
    When I compile this with ifort 14. it works but the assumed size function
    gives me a wrong result.
    Thank you
    Jan
    Steven_L_Intel1
    The internal compiler error is gone in 15.0.3, but the wrong results remain. However, the 16.0 beta works fine,so it looks as if this has already been fixed.
    Jan_W_2
    Oh ok!
    Thank you!
