29375 Discussions
Compatibility of Intel Visual Fortran Compiler 11.1.051 Professional Edition for Windows Year : 2009 WITH WINDOWS 7
Sina_K_
Hi all,
I got Intel Visual Fortran Compiler 11.1.051 Professional Edition for Windows . I read that this version is compatible for  Windows XP or Vista. I want to use this as my default  Fortran compiler. So the question is, is it compatible for  WINDOWS 7.  Any ideas will be greatly appreciated.
Thanks in advance.
mecej4
As you can see in the release notes at https://software.intel.com/sites/default/files/managed/55/db/release-notesf-111-w-en-u5.pdf , Windows 7 support was added in Intel Fortran 11.1.048, so your version should do fine.
I remember using 11.1.067 on Windows 7 for a couple of years, with no problems.
You may also consider installing the last release of 11.1, namely, 11.1.070, if you are eligible to obtain that update.
