DEC$ ATTRIBUTES DLLEXPORT attribute can not be assigned to an internal procedure
Dominic_C_1
I am trying to expose some Fortran subroutines in a DLL.
I didn't write the Fortran code, and I'm having some difficulties creating the DLL.
The Fortran code is something like this (simplified):
 ! Some declarations, initialisations etc
 contains
   subroutine Initialisation
   !DEC$ ATTRIBUTES DLLEXPORT::Initialisation
   !Do some stuff here
   end subroutine Initialisation
I keep getting this error:
DEC$ ATTRIBUTES DLLEXPORT attribute can not be assigned to an internal procedure.
I understand that this is because the subroutine is define underneath the "contains" keyword.
I've tried removing this but then I get a load more errors, so i'd rather not go down that route.
Is there an easy was of getting round this problem? I have googled for the error message but can't find a solution
Dom
Arjen_Markus
Not necessarily.
You could turn the program and the internal routine into a module. Something along these lines:
module myprogram
     ... declarations of the variables in the current main program
contains
subroutine the_old_program( only_init )
    logical :: only_init ! Use this to only initialise the variables that are needed in the internal routine
    if ( only_init ) then
   endif
end subroutine the_old_program
subroutine initialisation( .... )
   ! The current internal routine
end subroutine initialisation
end module myprogram
To use the_old_program subroutine in the testing context, use:
program test_myprogram
    use test_myprogram
    call the_old_program( .false. )
end program test_myprogram
Well, just a sketch.
Arjen
Arjen_Markus
You say it is an internal routine, but from the code it is not clear whether it is an internal routine (so belonging to a function or a subroutine) or a module procedure. If it is indeed an internal routine it can only be invoked from within the containing function or subroutine - whether it is all part of a DLL or a static library. If it is a module procedure, then it can be invoked from the outside, but it has to have the public attribute (which is the default).
Since it is not entirely clear what you have exactly, here are two fragments to show both situations:
integer function myfunc( x )
     integer, intent(in) :: x
     call my_helper( x, myfunc )
contains
subroutine my_helper( x, y ) ! Inside the function, so invisible from the outside!
     integer :: x, y
     ... do something useful ...
end subroutine my_helper
end function myfunc
And the other one is:
module mymodule
     private :: my_helper
contains
end function myfunc
subroutine my_helper( x, y ) ! Outside the function, but inside the module - note the private attribute
     integer :: x, y
end module mymodule
Dominic_C_1
Hi, thanks for the reply
The subroutine doesn't belong to a function or a subroutine, or a module. It belongs to the program (I really am unfamiliar with Fortran, and as I say, it's not my code).
The code is something like this (in fact, you can copy this dummy code exactly to get the error message I describe):
program MY_PROGRAM
  implicit none
! Lots of declarations here
  call Initialisation
 contains
end program MY_PROGRAM
Arjen_Markus
Right, that is a situation I forgot about :).
Since it is part of a program, it is meant to be used in conjunction with that program. That leads me to the question why this particular routine should be used outside it? Do you want to turn the program as such into a library for use in another program or is it simply this routine? Note that whatever your answer, you will have to adjust the code to a certain extent.
Arjen
Dominic_C_1
Hi Arjen,
It is simply this routine that I wish to call externally (actually, there are a few more routines that I wish to use, but in the same manner).
I'm not interested in the program (the program is just really a testbed which calls the subroutines in the same way that I wish to call them externally).
Steven_L_Intel1
You can't do this. An internal procedure requires context of its host to be passed and that's not available if you try to make it "external".
If the internal procedures don't need to inherit variables from the main program, move them to a module and USE the module from the main program. Then you can export them.
Dominic_C_1
Hi Steve,
Thanks for your reply
The internal procedures DO need to use variables that are declared in the main program.
I guess this is the problem I face.
I had previously been using the Silverfrost Fortran compiler to make a DLL, and that seemed to let me do what I wanted (expose internal procedures which had everything in scope when I ran them externally).
But then I ran into compile issues (because the Fortran developer who writes the code uses the Intel compiler, so I switched to Intel also).
Now I have these DLL issues. I don't really know what the best solution is to this. Probably get the Fortran developer to fix the Silverfrost compile issues and proceed from there.
Arjen_Markus
Not necessarily.
module myprogram
contains
   endif
    use test_myprogram
Arjen
Dominic_C_1
Thanks Arjen, that worked! :-)
The DLL has been created, and dependency walker shows the exported functions in the function list.
So my current problem has been solved.
Thanks very much
Dom
