29285 Discussions
Debugging ifort in VS 2022 17.7 hangs expression evaluator
AONym
New Contributor II
Just updated VS2022 from 17.6.x to 17.7.0. Now, none of the following work when using the VS debugger on Fortran code:
1) Data tips on stack variables give nothing.
2) Locals window is empty (shows busy...).
3) Attempt to add watch of a stack variable hangs (see attached screen shot), and now VS2022 is completely unresponsive.
This makes debugging Fortran code nearly impossible. Is there a fix? Would updating the compiler make any difference?
Windows 11, VS 7.7.0, ifort  2023.0.0. Complete details in attached VS about file.
Devorah_H_Intel
@wajahat @BrunoAmaral
Attached please find the preview update of VSIX installer for the latest FEE Visual Studio extension with a fix for the hang issue reported here.
Please let me know if the hanging issue is fixed for you in VS 17.7.
To install:
  • download and unzip attached VSIX installer
  • run the installer and follow prompts
NOTE: attached FEE VSIX installer for VS 17.7 is for testing only, VS 17.7 (released after oneAPI 2023.2 release) is not officially supported until next upcoming oneAPI HPC Toolkit release.
JohnNichols
Valued Contributor III
Jim:
Here is the VSIX in this stream
van_der_merwe__ben
New Contributor II
I am using Visual Studio 2022 version 17.7.5 and Intel Fortran Classic 2023.2. The debugger was hanging while debugging Fortran code. This fixed it for me, and I can now debug and see symbol values. Works perfectly. THANK YOU!!
ArunThomasArun
I am facing the same issue with
Microsoft Visual Studio Professional 2022
Version 17.8.4
VisualStudio.17.Release/17.8.4+34408.163
Microsoft .NET Framework
Version 4.8.04084
Installed Version: Professional
Visual C++ 2022 00483-10700-20176-AA419
Microsoft Visual C++ 2022
ADL Tools Service Provider 1.0
This package contains services used by Data Lake tools
ASA Service Provider 1.0
ASP.NET and Web Tools 17.8.358.6298
Azure App Service Tools v3.0.0 17.8.358.6298
Azure Data Lake Tools for Visual Studio 2.6.5000.0
Microsoft Azure Data Lake Tools for Visual Studio
Azure Functions and Web Jobs Tools 17.8.358.6298
Azure Stream Analytics Tools for Visual Studio 2.6.5000.0
Microsoft Azure Stream Analytics Tools for Visual Studio
C# Tools 4.8.0-7.23572.1+7b75981cf3bd520b86ec4ed00ec156c8bc48e4eb
C# components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Common Azure Tools 1.10
Provides common services for use by Azure Mobile Services and Microsoft Azure Tools.
CreateUnitTestBoilerplateCommand Extension 1.0
CreateUnitTestBoilerplateCommand Visual Studio Extension Detailed Info
Entity Framework Core Power Tools 2.5
Adds useful design-time EF Core DbContext features to the Visual Studio Solution Explorer context menu.
Fine Code Coverage FineCodeCoverage2022.ad53fb28-7a11-4465-a27a-3550499ea4a1
Visualize unit test code coverage easily for free in Visual Studio Community Edition (and other editions too)
GitFlow.VS.Extension 1.0
Visual Studio extension that integrates GitFlow
Microsoft Azure Hive Query Language Service 2.6.5000.0
Language service for Hive query
Microsoft Azure Stream Analytics Language Service 2.6.5000.0
Language service for Azure Stream Analytics
Microsoft Azure Tools for Visual Studio 2.9
Support for Azure Cloud Services projects
Microsoft JVM Debugger 1.0
Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual Machines
Node.js Tools 1.5.50908.1 Commit Hash:c294679b821c4b8f7f9c6db3827b7655db80fc28
Adds support for developing and debugging Node.js apps in Visual Studio
NuGet Package Manager 6.8.0
NuGet Package Manager in Visual Studio. For more information about NuGet, visit https://docs.nuget.org/
Rainbow Braces 1.0.155
Colorizes matching brace pairs to make it easy to identify them and their scope. Works for curly brackets, parentheses, and square brackets.
Razor (ASP.NET Core) 17.8.3.2358002+8c7fb27bf8e8d4f9ff8080b624b35bca5e812e97
Provides languages services for ASP.NET Core Razor.
SonarLint for Visual Studio 7.3.0.77872
SonarLint is an extension to your favorite IDE that provides on-the-fly feedback to developers on new bugs and quality issues injected into their code.
SQL Server Data Tools 17.8.120.1
Microsoft SQL Server Data Tools
ToolWindowHostedEditor 1.0
Hosting json editor into a tool window
TypeScript Tools 17.0.20920.2001
TypeScript Tools for Microsoft Visual Studio
Visual Basic Tools 4.8.0-7.23572.1+7b75981cf3bd520b86ec4ed00ec156c8bc48e4eb
Visual Basic components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Visual F# Tools 17.8.0-beta.23475.2+10f956e631a1efc0f7f5e49c626c494cd32b1f50
Microsoft Visual F# Tools
Visual Studio IntelliCode 2.2
AI-assisted development for Visual Studio.
ArunThomasArun
I am facing same issue as above for
Version 17.8.3
Version 4.8.04084
SQL Server Data Tools 17.8.119.0
Devorah_H_Intel
Version 17.8.3
Version 4.8.04084
There are no Intel compilers installed/integrated with VS based on the above output. Please repair or reinstall HPC Toolkit 2024
Barbara_P_Intel
What version of Intel Fortran are you using?
With the current release of Fortran VS 2022 17.8.2 hasn't been validated. See this article for more information.
Do you have a reproducer to share?
