29274 Discussions
Defined assignment with assumed rank dummy argument refuses to compile
Stijn_Schildermans
I am trying to implement a defined assignment for a derived type that is as generic as possible (i.e. the value I assign into is defined as class(*), dimension(..)). However, I can not get IFX to compile my code. Below is a minimal reproducing example:
module tesst
    implicit none
    type:: t
        integer:: val
    end type
    interface
        module subroutine get_val(val, tt)
            class(*), dimension(..), intent(out):: val
            type(t), intent(in):: tt
        end subroutine
    end interface
    interface assignment(=)
        module procedure get_val
    end interface
contains
        print *, 'Test'
    end procedure
end module
program test
    use tesst
    implicit none
    integer:: v
    type(t):: ttt
    v = ttt
end program
I am not using any compilation options (ifx -o test test.f90). The compilation error I get is:
'test.f90(36): error #6303: The assignment operation or the binary expression operation is invalid for the data types of the two operands.   [TTT]
   v = ttt
I do not understand this, since ttt is of type(t), which I believe it should be. I already found that the problem lies in the assumed rank for the argument val, but I do not understand what is wrong with my code. Any help is appreciated.
Steve_Lionel
Interesting. NAG Fortran gets an internal compiler error for this. I don't immediately see that this is invalid, but I will ask.
Steve_Lionel
Compiler bug in both compilers. Your example is valid, as far as I can tell. Would one of the Intel TCEs please file a report on this? Thanks.
Stijn_Schildermans
Thanks a lot for the confirmation! For now I implemented a workaround in my project using the classic interface with a defined procedure for each possible type of val, which works just fine.
Devorah_H_Intel
I have reported this bug to Compiler Engineering. It will be fixed in future releases.
