Errors with derived type containing array with negative bounds
Fábio_Mallaco
Trying to compile the following code with Intel Fortran Composer 17.0.0 results in a catastrophic internal compiler error.
module nrtype
    use iso_fortran_env
    implicit none
    integer, parameter :: itp = int8 ! Define quarter precision integer(1 bytes).
    integer, parameter :: ihp = int16! Define  half   precision integer(2 bytes).
    integer, parameter :: isp = int32! Define single  precision integer(4 bytes).
    integer, parameter :: idp = int64! Define double  precision integer(8 bytes)
    integer, parameter :: rsp = real32  ! Define single precision real ( 4 bytes). 7.22 decimal digits
    integer, parameter :: rdp = real64  ! Define double precision real ( 8 bytes). 14.95 decimal digits
    integer, parameter :: rqp = real128 ! Define quad   precision real (16 bytes). 34.02 decimal digits
end module nrtype
module modMesh
    use nrtype
    implicit none
    type DOFType(nEQs)
        integer(isp), len :: nEQs
        real(rdp) :: x
        real(rdp), dimension(nEQs) :: u, f, r
        real(rdp), dimension(nEQs,nEQs) :: fluxJac
    end type DOFType
    type cellType(nDOFs, nEQs)
        integer(isp), len :: nDOFs
        integer(isp), dimension(2) :: idFace
        integer(isp), dimension(2) :: idNb
        type( DOFType(nEQs) ), dimension(nDOFs) :: DOF
    end type cellType
    type faceType(nDOFs, nEQs)
        real(rdp) :: x
        type( cellType(nDOFs, nEQs) ), pointer :: nbL, nbR
    end type faceType
    type meshType(nCells, nGhosts, nDOFs, nEQs)
        integer(isp), len :: nCells
        integer(isp), len :: nGhosts
        integer(isp) :: nFaces
        type( faceType(nDOFs, nEQs) ), dimension(1-nGhosts:nCells+nGhosts) :: faceList
        type( cellType(nDOFs, nEQs) ), dimension(1-nGhosts:nCells+nGhosts) :: cellList
    end type meshType
    type( meshType(nCells=:, nGhosts=:, nDOFs=:, nEQs=:) ), target, allocatable :: mesh
end module modMesh
program test
    use nrtype
    use modMesh
    allocate ( meshType(5,5,1,1) :: mesh )
    mesh%cellList(-4)%DOF(1)%u(1) = 1.0
end program test
Replacing lines 50 and 51 for
        type( faceType(nDOFs, nEQs) ), dimension(-nGhosts:nCells+nGhosts) :: faceList
        type( cellType(nDOFs, nEQs) ), dimension(-nGhosts:nCells+nGhosts) :: cellList
prevents the compiler error but causes a segfault during execution.
Steven_L_Intel1
What compiler options are you using? I haven't been able to make it fail yet.
Fábio_Mallaco
I was compiling without any flag but you are right it stopped crashing here also, i don't know what could have changed. But still i get segfaults for both versions of the code.
Steven_L_Intel1
I can reproduce the segfault and have escalated it as issue DPD200414994. If you manage to see the internal compiler error again, please let us know the details.
