29248 Discussions
Failure of Lapack when OpenMP directive Enabled
criswu
    I build a project (vs2010 + IVF)  calling Lapack subroutines, but when I enable process OpenMP directives( Generate parallel code), and i encounted the
Debug Assertion Failed!
File:f:\dd\vctools\crt_bld\self_x86\crt\src\winsig.c
Line: 417
Expression:(" Invalid signal or error",0)
program main
implicit none
     integer,parameter:: NMAX = 4000
     integer,parameter:: LWORK = 100*NMAX
     integer IPIV(NMAX)
     complex WORK(LWORK)
     INTEGER LDA, INFO
     INTEGER maxedge ,error,ii
    Complex ,allocatable:: cmtx(:,:),crhs(:)
    maxedge = 1396
    allocate(cmtx(maxedge,maxedge),crhs(maxedge),stat=error)
    if(error .ne. 0)then
         print *,'Allocate cmtx and crhs failure'
         stop
    endif
    cmtx = (0.0,0.0)
    do ii = 1,maxedge
            cmtx(ii,ii) = (1.0,0.0)
    enddo
    print *,'Start LU decompostion '
    LDA = maxedge
    call CGETRF(maxedge,maxedge,cmtx,LDA,IPIV,INFO)
    if( INFO .eq. 0)then
             call CGETRI(maxedge,cmtx,LDA,IPIV,WORK,LWORK,INFO)
             if(INFO .eq. 0) print *,'LU Success'
    else
        print *,'Lapack Factor failure'
       stop
    endif
     stop
end program
TimP
You leave us guessing here.  It may be useful to have a build log,  If you installed the MKL option and specified an option such as /Qmkl your lapack functions should be linked from MKL, and there should be no conflicts due to linking multiple OpenMP libraries.  Did you rebuild, all with debug build, after changing the option?
criswu
I attached my whole program, and i linked my functions wth \Qmkl and enabled the \Qopenmp, it encounts the same error.
criswu
By modifing
complex WORK(LWORK)
to
complex,allocatable : WORK(:)
and the allocate the array WORK(LWORK) can fix this problem.
