I build a project (vs2010 + IVF) calling Lapack subroutines, but when I enable process OpenMP directives( Generate parallel code), and i encounted the
Debug Assertion Failed!
File:f:\dd\vctools\crt_bld\self_x86\crt\src\winsig.c
Line: 417
Expression:(" Invalid signal or error",0)
program main
implicit none
integer,parameter:: NMAX = 4000
integer,parameter:: LWORK = 100*NMAX
integer IPIV(NMAX)
complex WORK(LWORK)
INTEGER LDA, INFO
INTEGER maxedge ,error,ii
Complex ,allocatable:: cmtx(:,:),crhs(:)
maxedge = 1396
allocate(cmtx(maxedge,maxedge),crhs(maxedge),stat=error)
if(error .ne. 0)then
print *,'Allocate cmtx and crhs failure'
stop
endif
cmtx = (0.0,0.0)
do ii = 1,maxedge
cmtx(ii,ii) = (1.0,0.0)
enddo
print *,'Start LU decompostion '
LDA = maxedge
call CGETRF(maxedge,maxedge,cmtx,LDA,IPIV,INFO)
if( INFO .eq. 0)then
call CGETRI(maxedge,cmtx,LDA,IPIV,WORK,LWORK,INFO)
if(INFO .eq. 0) print *,'LU Success'
else
print *,'Lapack Factor failure'
stop
endif
stop
end program
You leave us guessing here. It may be useful to have a build log, If you installed the MKL option and specified an option such as /Qmkl your lapack functions should be linked from MKL, and there should be no conflicts due to linking multiple OpenMP libraries. Did you rebuild, all with debug build, after changing the option?
By modifing
complex WORK(LWORK)
to
complex,allocatable : WORK(:)
and the allocate the array WORK(LWORK) can fix this problem.
