File position inquiry with non-advancing formatted stream access and sheep
IanH
I've never been good at poetry... so I've started using Fortran to help me.  Getting the right number of syllables in each line has always been tricky, so sometimes I skip over bits, and then fill them in later.
PROGRAM poetic_streaming
  IMPLICIT NONE
  INTEGER :: unit
  INTEGER :: pos
  OPEN(  &
      NEWUNIT=unit,  &
      FILE='poetry.txt',  &
      FORM='FORMATTED',  &
      ACCESS='STREAM',  &
      ACTION='WRITE',  &
      STATUS='REPLACE' )
  WRITE (unit, "(A)", ADVANCE='NO') 'Mary had a '
  ! Remember where we are and leave a placeholder for now.
  INQUIRE(unit, POS=pos) ; print *, pos
  WRITE (unit, "(A7)", ADVANCE='NO') ''
  WRITE (unit, "(A)") ' processor'
  WRITE (unit, "(A)") 'ifort was its name'
  WRITE (unit, "(A)") 'but support for querying the file position after non-advancing formatted stream access output was broken'
  WRITE (unit, "(A)") 'so she had to rethink her game'
  WRITE (unit, "(A7)", POS=pos, ADVANCE='NO') 'Fortran'
  CLOSE(unit)
END PROGRAM poetic_streaming
Alas...
>ifort /check:all /warn:all /standard-semantics "2015-11-21 poetic_streaming.f90" && "2015-11-21 poetic_streaming.exe" && type poetry.txt
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0 Build 20151021
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 10.00.40219.01
Copyright (C) Microsoft Corporation.  All rights reserved.
"-out:2015-11-21 poetic_streaming.exe"
-subsystem:console
"2015-11-21 poetic_streaming.obj"
 1
Fortran
a         processor
ifort was its name
I think I spy a stray newline in there too.
Steven_L_Intel1
Baaaa-d. We'll haul out the shepherd's crook for this if need be.
