Comunicados
*G0 data edit descriptor
OP1
Novo colaborador III
1.667 Visualizações
Consider the following code, which outputs the content of an array in a string of the form [value,value,value]
PROGRAM P
IMPLICIT NONE
INTEGER,ALLOCATABLE :: A(:)
A = [1,2,3]
WRITE(*,FMT='("[",<SIZE(A)-1>(G0,","),G0,"]")') A
WRITE(*,FMT='("[",*(G0,","),"]")') A
WRITE(*,FMT='("[",3(G0,","),"]")') A
END PROGRAM
The output is:
[1,2,3]
[1,2,3,
[1,2,3,]
1. Although it is not standard-conformant (it's an Intel extension I believe), the first option works as intended when SIZE(A)>1. Is there a nifty trick to make this work when SIZE(A) is 1?
2. Options 2 and 3 show a different behavior - is this a bug with the simultaneous use of * and the G0 edit descriptor?
3 Respostas
IanH
Colaborador honorário III
1.667 Visualizações
#2 and #3 should not be the same.  F2008 10.4p6
Whenever format control encounters a data edit descriptor in a format specification, it determines whether there is a corresponding effective item supplied by the input/output list.  If there is such an item, it transmits appropriately edited information between the item and the record, and then format control proceeds.  If there is no such item, format control terminates.
In the case of #3, the format control doesn't encounter a data edit descriptor without a corresponding effective item (because the repeat count matches the number of items) so it trundles all the way to the end of the specification, while the unlimited repeat count is effectively the same as if the repeat count was a very large number - so extra data edit descriptors are encountered.
I'd just do this using non-advancing input.
WRITE(*,FMT='("[",*(G0,:,","))', ADVANCE='NO') A
WRITE(*,FMT='("]")')
I don't use the intel extension thing.  Where necessary I just build the format specification, with appropriate repeat counts or field widths, up manually using internal writes.
Steven_L_Intel1
Funcionário
1.667 Visualizações
FWIW, Variable Format Expressions (#1 in OP's post) were a DEC extension, carried through to Intel. Other vendors rue the day we came up with this feature, and they have caused us no end of trouble over the years as well (due to their being a "callback" during I/O. Think of it as an early form of User-defined Derived Type I/O.
OP1
1.667 Visualizações
Thanks Steve and IanH for the explanations!
Responder
