29245 Discussions
GlutilsMOD.f90 does not compile with XE 2017
chunky_lover_23
Trying to rebuild my programs on XE2017 (ID w_comp_lib_2017.4.210)  under Microsoft Visual Studio Enterprise 2015 (Version 14.0.25431.01 Update 3)
Get an error:
error #8752: This derived type component of an interoperable type is not itself interoperable (does not have the BIND(C) attribute).   [PALPALENTRY]
Any Ideas
Snippet from code see: below:
! Declare our own type for LOGPALETTE - the one in IFWINTY has just
! one element. The C code used malloc, and there are various Fortran
! ways we could fudge this, but the following seems simplest. Note that
! there is a 256-entry limit to a palette.
type, bind(C) :: OUR_LOGPALETTE
integer(WORD) palVersion
integer(WORD) palNumEntries
TYPE (T_PALETTEENTRY) palPalEntry(0:255)
andrew_4619
        type :: OUR_LOGPALETTE
              sequence
        end type OUR_LOGPALETTE
Removing bind(c) and add sequence works.
andrew_4619
              sequence
andrew_4619
Otherwise you would need to define your own type  MY_T_PALAETTENTRY with bind(c)
chunky_lover_23
Thank you Andrew.  The "sequence" option works a treat..
