Help making a dll
tmadden
I'm calling an IntelFortran dll from VB6, and I get the error message : "Bad dll Calling Convention"on the line that calls the dll.
WhenI debug the program, the dll does operate on the integer, but then it gives the error. I've included all my code. This is my first attempt at a dll, so sorry in advance if its a simple question.
Code:
VB Form 1:
Option Explicit
Private Sub Command1_Click()
Dim I As Integer
I = 20
MsgBox (I)
SimpleFortranSub I
MsgBox (I)
End Sub
VB Module1:
Option Explicit
Declare Sub SimpleFortranSub Lib "C:dev2EXAMPLESimpleFortranSub.dll" (ByRef I As Integer)
Fortran DLL:
subroutine SimpleFortranSub (TestInt)
  !DEC$ ATTRIBUTES DLLEXPORT::SimpleFortranSub
  !DEC$ Attributes alias : "SimpleFortranSub" :: SimpleFortranSub
  Integer*2 TestInt
  TestInt = TestInt + 1
end subroutine SimpleFortranSub
Message Edited by tmadden@linkamericacorp.com on 12-21-2004 06:56 AM
Message Edited by tmadden@linkamericacorp.com on 12-21-2004 07:56 AM
durisinm
tmadden@linkamericacorp.com wrote:
I'm calling a Fortran dll from Visual Basic, and I get the error message : "Bad dll Calling Convention"on the line that calls the dll.
Code:
VB Form 1:
Option Explicit
Dim I As Integer
I = 20
MsgBox (I)
SimpleFortranSub I
MsgBox (I)
End Sub
VB Module1:
Option Explicit
Shouldn't the VB call the DLL with Call SimpleFortranSub(I)?
Mike D.
durisinm
Shouldn't the VB code call Fortran with Call SimpleFortranSub(I)?
Mike D.
Message Edited by durisinm on 12-21-2004 07:35 AM
tmadden
Thanks for taking a look. I believe either method should work fine.
From the VB6 Help Files:
"There are two ways to call a Sub procedure:
' Both of these statements call a Sub named MyProc.
Call MyProc (FirstArgument, SecondArgument)
MyProc FirstArgument, SecondArgument
Note that when you use the Call syntax, arguments must be enclosed in parentheses. If you omit the Call keyword, you must also omit the parentheses around the arguments. "
Message Edited by tmadden@linkamericacorp.com on 12-21-200407:45 AM
Message Edited by tmadden@linkamericacorp.com on 12-21-2004 07:45 AM
Steven_L_Intel1
When using Intel Fortran, you need to add the STDCALL and REFERENCE attributes to the Fortran routine to make it match what VB is looking for.
tmadden
Thanks for the help.
I restarted using your advice, and it worked!
Code:
Mod:
Private i As Integer
Declare Sub Fadd Lib "C:dev2FCallF.dll" (i As Integer)
Form:
Dim iVB As Integer
iVB = 20
Fadd iVB
MsgBox (iVB)
End Sub
Fortran DLL:
subroutine Fadd(i)
    !DEC$ ATTRIBUTES DLLEXPORT, Alias: "Fadd" :: Fadd
    !DEC$ ATTRIBUTES STDCALL :: Fadd
    Integer*2 i
    !DEC$ ATTRIBUTES REFERENCE :: i
    i=i+1
end subroutine Fadd
Message Edited by tmadden@linkamericacorp.com on 12-21-2004 11:25 AM
