Help wanted calling DLLs from 64-bit versions of Excel
DavidWhite
Valued Contributor II
I am calling a Fortran DLL from Excel VBA, and have ben doing so successfully for years.
Now one of our engineering suppliers is using a 64-bit version of Office (we haven't migrated from Office 2007 yet).
Can someone help me with my interfaces?
I am using calls like
Private Declare Sub ApproxBayerDensity_F Lib "AHEAProps.dll" (TempC As Double, Value As Double, ByVal Units As String)
Call ApproxBayerDensity_F(T, Value, Units)
the Fortran side is like
Subroutine ApproxBayerDensity_F(TempC, Value, Units)
!DEC$ ATTRIBUTES DLLEXPORT, STDCALL, ALIAS:'ApproxBayerDensity_F' :: ApproxBayerDensity_F
!DEC$ ATTRIBUTES REFERENCE :: Units
IMPLICIT NONE
Real (KIND=8),INTENT(IN) :: TempC(1)
Real (KIND=8),INTENT(OUT) :: Value(1)
Character (LEN=20),INTENT(INOUT) :: Units
For the 64-bit interface, I now need to use
Private Declare PtrSafe Sub ApproxBayerDensity_F Lib "AHEAProps.dll" (TempC As Double, Value As Double, ByVal Units As String)
Where the variables have to be compatible with the 64-bit Excel.
Do I need to change anything on the Fortran side?
David
Steven_L_Intel1
I don't see anything that has to change on the Fortran side.The STDCALL won't have any effect in this case (you've effectively overridden the effects it would have on x64), but that's harmless.
DavidWhite
Thanks. Steve. What about integer values? On the VBA side, these are now defined as LongPtr instead of Long. Do these still map OK to INTEGER? thanks, David
Steven_L_Intel1
LongPtr would be INTEGER(8) on x64.
