How do I compile XE 2016 exe for Windows XP so it is not invalid Win32
Chris_H_3
Hello.  Using VS2015 pro with parallel XE 2016 fortran, I compile a simple 'Hello World' console app with x86 config.  Copying the exe to an XP machine and running it on the command line gives 'Invalid Win32' application error.  I tried not building the manifest file and NOT suppressing the startup logo, but I still get the same result.  Any help with this would be appreciated.  Thank you.
Sincerely,
CHobbs
jimdempseyatthecove
Choose Win32 configuration platform, not x86
Jim Dempsey
andrew_4619
read https://software.intel.com/en-us/articles/linking-applications-using-visual-studio-2012-to-run-on-windows-xp
Chris_H_3
Hello!  Thank you for the suggestion.  I was hoping for an aha moment, but when I looked in the configuration manager the 'x86' build had the Win32 platform checked.  That was the only build/platform choice I had.
Chris_H_3
This was sent to me by andrew_4619 not on this board and it worked!
