29277 Discussions
How to build in QuickWin project
ywangsiom
I have added several f90 files into source files within quickwin project. When i compiled them, it always report couldnot find *.mod. These modules are being defined in other f90 files. Does someone know the reason?
anthonyrichards
New Contributor III
Normally of course, you would expect a compiler to recognise a FORTRAN file containing MODULE code and compile it THEN compile files that USE the module. As a work around, just select the module files yourself and compile them individually, then build the rest of the project. The modules should be found and all should then proceed normally.
Steven_L_Intel1
In CVF, it is normal to get this message when first building a project. I don't see it in IVF. If it persists, try a "Rebuild".
