How to find out what Intel compiler version that created a binary file?
youn__kihang
Hello All,
I have some execution files that are created by Intel fortran compilers and Intel MPI libraries.
Is there a way to check what compiler the file is made of?
I was trying to find any methods but I can't find.
Please let me know if it exists.
andrew_4619
I opened an exe file in Notepad++  and did some searches. I found this string that may or may not be helpful....
"Intel Fortran RTL Message Catalog    V19.0-001 May 11 2018"
JohnNichols
Valued Contributor III
https://docs.microsoft.com/en-us/windows/win32/debug/pe-format
I would start here -- the file format is explained in detail -- you may have to make educated guesses based on the information you will find.
youn__kihang
Thanks for help, Nichols
The URL is valuable for advanced windows user. But I am trying to check the version in Linux system.
For example, I have two exec files and one is built by Intel fortran v19 and IMPI v19 and another is built by Intel fortran v18 and IMPI v18.
Then how can I find out what exec file built by version 19 without specific file name(because it is indistinguishable).
JohnNichols
https://en.wikipedia.org/wiki/Executable_and_Linkable_Format
Get a binary file reader and look at file headers -- look at the compile dates if they show up and then line then up with release dates for the compilers
andrew_4619
Steve_Lionel
There is no obvious way to know. At best you can look at the date the executable was created and eliminate any later releases. But if you find a useful string, as Andrew did, that could be a hint. The compiler itself doesn't put in anything that would tell you, unless (on Linux only) you use the -sox option.
youn__kihang
Thank you all,
Various users have been inquiring about library issues(compile/executive library differences),
but I haven't been able to identify problems that come from different compilation and execution environments.
I think I can solve it using the notepad method you told. Thank you!
Steve,
What command should I use when I look at the contents of a file compiled with sox? The Intel options description is shown below.
"It is then possible to use a tool, a search as a stress utility, to meet what options we used to build the Executive File."
Thank you again.
Steve_Lionel
When compiled with -sox, use a "strings" command to find strings in the executable. Again, this is Linux-only. (It used to work on Windows until Microsoft changed the linker to throw away such "comment" strings. It's not supported on Mac either, but I am unsure why.)
