[ICE] IPO causes internal compiler error during linking
Kacper_Kowalik
Hi,I've a self written Fortran 2008 code[1] and recently I've started to experience ICE with -fast option, during linking phase:[bash]mpif90 -L/opt/intel/hdf5/lib -L/opt/intel/fgsl/lib -o piernik *.o -lhdf5_fortran -lhdf5hl_fortran -lhdf5_hl -lhdf5 -lz ipo: remark #11000: performing multi-file optimizations ipo-1: remark #11006: generating object file /tmp/ipo_ifortOphlz41.o ipo-2: remark #11006: generating object file /tmp/ipo_ifortOphlz42.o ipo-4: remark #11006: generating object file /tmp/ipo_ifortOphlz44.oipo-3: remark #11006: generating object file /tmp/ipo_ifortOphlz43.o 20000_0 fortcom: Severe: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error. ipo-4: error #11005: multi-object compilation 4 returned error status 3 ifort: error #10014: problem during multi-file optimization compilation (code 3)[/bash]Unfortunately, I cannot reduce it to simple testcase. My question before I provide further details: what would be the most convenient way to tackle this? The code depends on external libs (MPI, >=HDF5-1.8.9). I can provide any assistance needed to create bootstrap environment should you try to reproduce it and/or access to machine where all is set.Best regards,Kacper Kowalik[1] http://piernik.astri.umk.pl/ ;
Steven_L_Intel1
What does "ifort -V" say?  Do you get the same thing with just -ipo ? We'll take the full test case if you can't reduce it.
Kacper_Kowalik
Fails the same way with just F90FLAGS=-r8 -ipo.
[bash]xarth@sandbox ~/codes/trunk/obj $ ifort -V
Intel® Fortran Intel® 64 Compiler XE for applications running on Intel® 64, Version 12.1.5.339 Build 20120612
Copyright (C) 1985-2012 Intel Corporation.  All rights reserved.[/bash]
Perhaps I could also test with current prerelease version if that's possible? Just to make sure we are not chasing bug that's already been fixed...
Steven_L_Intel1
You won't have to wait too long (few weeks) to get the next version. Just do without -ipo for now.  If it still fails with 13.0, let us know.
Kacper_Kowalik
Works as a charm with 13.0 Thanks!
Steven_L_Intel1
Glad to hear it.
