29295 Discussions
ICE with an extended parameterized derived type (PDT)
FortranFan
module m
   use, intrinsic :: iso_fortran_env, only : i4 => int32, i8 => int64
   implicit none
   type :: base_t(k,n,m)
      integer, kind :: k = i4
      integer, len  :: n = 1
      integer, len  :: m = 1
   end type base_t
   type, extends(base_t) :: t
      integer(kind=k) :: a(n,m)
   end type t
   interface assignment(=)
      module procedure seta_i4
      module procedure seta_i8
   end interface
contains
   subroutine seta_i4(t_lhs, a_rhs)
      class(t(k=i4,n=*,m=*)), intent(inout) :: t_lhs
      integer(kind=i4), intent(in)          :: a_rhs(:,:)
      t_lhs%a = a_rhs
      return
   end subroutine seta_i4
   subroutine seta_i8(t_lhs, a_rhs)
      class(t(k=i8,n=*,m=*)), intent(inout) :: t_lhs
      integer(kind=i8), intent(in)          :: a_rhs(:,:)
      t_lhs%a = a_rhs
      return
   end subroutine seta_i8
end module m
1>------ Build started: Project: p, Configuration: Debug x64 ------
1>Compiling with Intel(R) Visual Fortran Compiler 16.0 [Intel(R) 64]...
1>m.f90
1>m.f90(29): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
1>compilation aborted for m.f90 (code 1)
Yuan_C_Intel
Thank you for raising the issue.
I have reproduced it with 16.0 and entered the issue into our problem-tracking system: CQ DPD200376548.
I will let you know when I have an update on this issue.
