29234 Discusiones
ICE with ifx -assume norealloc_lhs -check all
JacekDziedzic
Principiante
1.720 Vistas
module mwe
contains
  subroutine fail(a,b)
    implicit none
    integer, intent(out), optional :: a
    integer, intent(out), optional :: b
    integer :: args_present
    args_present = sum(merge(1,0,[present(a),present(b)]))
  end subroutine fail
end module mwe
The above trivial module ICEs ifx 2025.1.0 20250317, but only with this command line:
ifx -assume norealloc_lhs -check all mwe.F90
Dropping either of the options makes the compiler behave.
0 kudos
3 Respuestas
Ron_Green
Moderador
1.661 Vistas
It's the -check shape along with -assume norealloc_lhs combo.  I can see how the compiler could get confused about how to check shape when you say to not create an temp for the LHS in this case.  Easy for us to see that the result of the expression on the LHS is a simple scalar, but it's a merge of an array which is then sum'med.
I will get a bug report started.  Until there is a fix you can use
-warn all,noshape
to prevent the error.
Thank you for a simple and easy to understand sample.
Ron_Green
Moderador
1.656 Vistas
bug ID is CMPLRLLVM-68884
JacekDziedzic
Principiante
1.540 Vistas
Thank you for making this into a bug ID and for the suggested workaround. We found that a simple replacement of
sum(merge(1,0,[...]))
with
count([...])
made the compiler behave.
Responder
